LED turn signals not working
Old Mar 20, 2011 | 09:01 AM
flstsihdca's Avatar
flstsihdca
6th Gear
Default LED turn signals not working
I installed new rear LED turn signals on my 2003 FLSTSI. At first they would blink normally 3 or 4 times, than really fast. After a couple rides they stopped working at all. The stock front ones continue to work fine. I've since installed a load equilizer (Badlander) and still nothing. Thinking I may have cooked them, I spliced in a new one (LED turn signal) to be sure, and still nothing. I was told, even without the load equilizer, the lights should remain in tact only would not function properly.
Any suggestions?
Thanks
Old Mar 20, 2011 | 09:43 AM
SuspendedUser's Avatar
SuspendedUser
i would try disconnecting the battery altogether - reconnect and try again with the LE
Old Mar 20, 2011 | 10:13 AM
flstsihdca's Avatar
flstsihdca
6th Gear
Recently installed a new battery.
Old Mar 20, 2011 | 10:40 AM
IAMSWUTIAMS's Avatar
IAMSWUTIAMS
Switch the polarity. LED's are polarity sensitive.
Old Mar 20, 2011 | 10:53 AM
IAMSWUTIAMS
On the lights, not the battery. Thought Id clarify.
Old Mar 20, 2011 | 11:35 AM
flstsihdca's Avatar
flstsihdca
6th Gear
I'll give that a try.
Old Mar 20, 2011 | 08:11 PM
flstsihdca's Avatar
flstsihdca
6th Gear
Still nothing.
Old Mar 20, 2011 | 08:34 PM
SuspendedUser
i meant, disconnect it so the ecm looses power completely, not "the battery is dead" just a tought thou... dont know if its going to work.
Old Mar 21, 2011 | 08:10 AM
handyhoward's Avatar
handyhoward
Follow the instructions that came with the Badlander on resetting the OEM module.
Old Mar 21, 2011 | 06:27 PM
flstsihdca's Avatar
flstsihdca
6th Gear
Will do. I'll let you how I make out.
Thanks.
