2 inch extended forwords
Old Mar 24, 2011 | 01:55 PM
RICHIEMACK's Avatar
RICHIEMACK
Default 2 inch extended forwords
Im looking to install a set of 2 inch extended forword controls.how long of a job? And can i take the brake line off the frame clips and maybe get enough extra so i do not have to get a longer brake line,i have no exp. In bleeding brakes and a indy told me it was a 3 hour job? Any help guys would be great...thanks richie...alsoi guess i need a new k stand since the stock mount is on the old controls??
Old Mar 24, 2011 | 03:13 PM
Ash16's Avatar
Ash16
Don't know about the 2" but I installed the ness 3 inch extensions over a year ago. It was an easy job. They came with an extended brake line and the kickstand moves forward with everything else. To make brake bleeding easier get a set of speed bleeders or a mityvac.
Old Mar 24, 2011 | 03:28 PM
RANGER73's Avatar
RANGER73
Did mine, 3" also no brake bleeding involved. Came with extension rod (I have a frame mounted master cylinder). You will need a bike jack or a way to tie your bike off so it don't fall over, as you will be removing the jiffy stand.
Also don't forget toe locktight. You might need a new shift peg mine was red locktighted on and I snapped the bolt. Only took me an hour.
Old Mar 24, 2011 | 04:40 PM
RICHIEMACK's Avatar
RICHIEMACK
This is not the kit,thees are new full contols and pegs and shifter peg,i already got the longer shifter rod,and its a new brake res.you guys had the plate kit..so im still in guestion,but thanks anyways
Old Mar 24, 2011 | 04:43 PM
RICHIEMACK's Avatar
RICHIEMACK
Originally Posted by ranger73
did mine, 3" also no brake bleeding involved. Came with extension rod (i have a frame mounted master cylinder). You will need a bike jack or a way to tie your bike off so it don't fall over, as you will be removing the jiffy stand.
Also don't forget toe locktight. You might need a new shift peg mine was red locktighted on and i snapped the bolt. Only took me an hour.
i see you went with the rear k stand,did you have to drill and tapthe frame?
Old Mar 24, 2011 | 05:23 PM
Tx_Outlaw's Avatar
Tx_Outlaw
There is a Ness rear stand that mounts right up to the holes already in the frame on the left side. Opposite the exhaust mounts on the right. Since the master cylinder has the side output, the stock brakeline may work. The swap is very easy and so is bleeding the brake. Don't let a mech tell you it's a 3 hour job.....
Old Mar 24, 2011 | 05:39 PM
RICHIEMACK's Avatar
RICHIEMACK
Originally Posted by tx_outlaw
there is a ness rear stand that mounts right up to the holes already in the frame on the left side. Opposite the exhaust mounts on the right. Since the master cylinder has the side output, the stock brakeline may work. The swap is very easy and so is bleeding the brake. Don't let a mech tell you it's a 3 hour job.....
you should know..lol...yea i found a nice 11 inch 3 hole plate that will go right over the conrols ,easyer than drilling and tapping a rear mount,,demon cycle $ 69..the ness is almost what i paid ray for the contols,,lol....i figure if all goes good 1hour,thats if i can use the brake line,if i take the frame clips off i will have some slack
Old Mar 26, 2011 | 06:16 AM
RICHIEMACK's Avatar
RICHIEMACK
Originally Posted by ash16
don't know about the 2" but i installed the ness 3 inch extensions over a year ago. It was an easy job. They came with an extended brake line and the kickstand moves forward with everything else. To make brake bleeding easier get a set of speed bleeders or a mityvac.
so the extended brake line goes from the resivor to where?
Old Mar 26, 2011 | 10:00 AM
Tx_Outlaw's Avatar
Tx_Outlaw
Reservoir to the brake light switch box just in front of the swingarm.
Old Mar 27, 2011 | 11:27 AM
Ash16's Avatar
Ash16
^ What TX said.
