heritage fork lock replaement
Old Mar 31, 2011 | 02:49 PM
dave hill's Avatar
dave hill
5th Gear
Default heritage fork lock replaement
Having trouble changing my fork lock on my 2000 heritage. The ignition switch went bad so I went to Freedom (thats my local H.D. dealer) and bought a switch kit. It came with new switch ,plastic plug, and fork lock. Change switch and plug, then started on fork lock.I drill out the hole where set screw goes and removed set screw. then tried to pull switch out. Well it came out about an 1/8th of an inch and would go no further. Im I missing something or does it come out that hard? Need help with this one. Hope someone knows what I missed. Thank You
Old Mar 31, 2011 | 08:21 PM
Trey Hogger's Avatar
Trey Hogger
I looked in the service manual and couldn't find any direction on removal. Looked at mine, and other than wondering if the forks need to be turned a certain direction for it to slide out, have no clue. Sure you're not trying to pull it out while in the locked position?
Old Mar 31, 2011 | 10:00 PM
Rakthi's Avatar
Rakthi
Found this in the 2007 service manual (don't think they changed this part much over the years):
REMOVAL
1. Remove fork stem. See 2.23 STEERING HEAD.
2. See Figure 2-152. Remove set screw (1).
3. Insert key (3) in lock (2) and turn partially.
4. Wiggle lock and pull until enough of the lock comes out
to get a grip with pliers or other suitable tool.
5. Rotate steering stem slightly, while pulling on lock until
lock is removed.
Looks like this is more involved than you would think ... have to remove the fork stem! Kind of makes sense, if it would as simple as taking out the set screw and pulling the lock, would make is pointless to lock the bike.
Old Apr 2, 2011 | 09:28 AM
dave hill's Avatar
dave hill
5th Gear
Thanks for the reply guys, was really having trouble getting infomation on this one.Thanks again Trey and Rakthi
LongBeard Outlier
May 29, 2017 07:57 PM
rwven
2014-2024 Touring Models
11
Mar 21, 2017 07:37 AM
langwilliams
May 19, 2015 04:36 AM
chorndawg
May 10, 2012 10:08 AM
rshwetz
May 9, 2010 12:09 PM
