head gasket 01 softtail evo
Old Mar 31, 2011 | 07:27 PM
steve82172's Avatar
steve82172
Default head gasket 01 softtail evo
I have a bad head gasket on a motor that has about 8K on rebuild . it was running pretty bad and discoverd the head gasket problem a leak down test confirmed my thaughts. now i need to know what is involved in replacing this and if a person that is pretty handy with a wrench but not a pro, I have done full engine rebilds on cars and such can undertake with out a complete mess of special tools i understand that the head bolts need a special wrench. should i replace the the base gasket or o ring not sure what it is as both have been referd to in other forums. any info would be greatly appreciated
Old Mar 31, 2011 | 08:35 PM
stevelonewolf's Avatar
stevelonewolf
If you can read a sevice manual, you can do it. Unless it's a custom bike, an 01' is not an evo,it's a twin cam. Also,if you plan on doing the one,do the other head gasket as well.
Old Apr 1, 2011 | 06:06 AM
Mike T's Avatar
Mike T
Replace the head gaskets with Cometic, torque to spec and you won't have to worry about blown head gaskets anymore.
Old Apr 2, 2011 | 07:47 AM
steve82172's Avatar
steve82172
it is a custom and i am not 100% on the evo but my research tells me evo
Old Apr 2, 2011 | 07:48 AM
steve82172's Avatar
steve82172
that is the brand the suplier told me to use alo thanks
Old Apr 2, 2011 | 09:19 AM
Doug S's Avatar
Doug S
Take a read through here: there is a table with the differences.
http://en.wikipedia.org/wiki/Harley-...win_Cam_engine
I had a 99 FXSTC and it was the last EVO year for that model.
You don't have to do the base gaskets but I kind of think that if the head gasket went after only 8K, I would suspect either cheap gaskets or a so-so builder and would probably do it all.
D
Old Apr 2, 2011 | 09:40 AM
PanHeadRich's Avatar
PanHeadRich
If you can't visually see the difference between an Evo and a Twin Cam, I'd leave the wrenching to the pro's. I'm not trying to be a jerk, but it amazes me that you don't even know what motor you have. Post a pic of the engine so others can tell you what you have.
EVO
TWIN CAM
Old Apr 2, 2011 | 11:05 PM
steve82172's Avatar
steve82172
EVO
TWIN CAM
i was 99% i had an evo motor and i did verify that given i had confliting report that in 01 a softail had the tc it made me question what i had but i do have an evo and i do understand your point if i dont know what i have let the pros fix it
Old Apr 2, 2011 | 11:22 PM
steve82172's Avatar
steve82172
head gaskets replaced went well, and replaced lowers also was pretty easy but now i have a bad oil leak on the one of my push rod tubes i assume i messed up an o ring or its not seated properly has any one had an issue such as this is there an obvious mistake i made other than me working on it ha ha ha . by the way it is on 01 custom bike not harley frame or much else for that mater with the harley evo motor pretty much a stock motor bored .020 over and now has .030 head gaskets instead of .045 thickness. cases are stamped s and s instead of harley but jugs up all stamped hd
Old Apr 3, 2011 | 06:51 AM
Mike T's Avatar
Mike T
Make sure the push rod tubes are seated good with an o-ring in place. They normally don't leak.
