Need help before I pull primary
Old Apr 6, 2011 | 04:45 PM
purecountry13b's Avatar
purecountry13b
Default Need help before I pull primary
Hello all,
I'm leaving on monday for four months to beautiful Camp Shelby MS, and Ft. Polk. In a time crunch and do intend to get a service manual when I get back. But first I am going to break the Bones down for PC. I want to pull the primary, timing cover, derby and trans cover off. Anything special I need to know? I know there is oil in the primary. As I said I will have the manual to put the shtuff back together, but don't have time to wait for one now. Any help is appreciated.
Old Apr 6, 2011 | 04:50 PM
Sgt_Jim's Avatar
Sgt_Jim
1) Replace all of your gaskets.. the manual specifically states that at least with the Primary cover, every time you remove it, you need to replace the gasket.
2) Keep your bolts separated..a labelled ziplock bag is a good way.
3) When all else fails, get a bigger hammer.
Old Apr 6, 2011 | 04:55 PM
tlb's Avatar
tlb
Drain your fluids, Pull your footboards, pull your exhaust and remove the covers. It is all pretty straight forward. Cover everything up with plastic while you are gone, so nothing gets inside.
I would be a little worried about having all of it opened up, without any fluids for 4 months, if you have any worry about condensation.
You will need snap ring pliers for the trans cover, dont drop the bearings.
Old Apr 6, 2011 | 05:08 PM
purecountry13b
What bearings!!
Old Apr 6, 2011 | 06:23 PM
tlb's Avatar
tlb
The ones under the ramp, on the transcover. You will take off the snap ring then remove the ramp, the bearing are under there.
Loosen clutch adjuster so clutch cable is fully slack
. See
1.12 CLUTCH
2. See F
igure 2-119. Remove remove the retaining ring (2)
and pivot pin (4). Remove the c
lutch cable anchor pin (1)
from the hand leve
r.
3. Drain transmiss
ion lubricant and remove fill plug dipstick.
Remove transmission side cove
r. See 7.4 TRANSMISSION
CLUTCH RELEASE COVER.
. See Figure 2-120. Note position of retaining ring opening.
Retaining ring opening must be positioned in
approximately the same location dur
ing assembly.
Remove retaining ring (1)
. Pull inner ramp (2) and coupling (3) out of side cover.
Hold inne
r and outer ramps together to keep ***** from
falling f
ree.
. Rotate the inner ramp to a position which will allow the
coupling to be disconnected from the inner ramp lever
arm. Disconnect coupling from
inner ramp. Disconnect
cable end (4) from coupl
ing.
7. Back out threaded cable fitting (5) from side cover.
Originally Posted by purecountry13b
What bearings!!
Old Apr 6, 2011 | 06:34 PM
stevelonewolf's Avatar
stevelonewolf
. See
1.12 CLUTCH
2. See F
from the hand leve
r.
3. Drain transmiss
ing assembly.
Hold inne
falling f
ree.
ing.
LMAO! tlb, I think you scared the crap out of him on that one!
Old Apr 6, 2011 | 07:04 PM
purecountry13b
Yup, holly ****. gonna wait on the trans.
Old Apr 6, 2011 | 07:20 PM
tlb's Avatar
tlb
It is really easy, Just need to be careful when you remove the ramp, only 3 ***** in there.
Old Apr 6, 2011 | 07:32 PM
purecountry13b
I used a ramp once to put my bike in a truck once. Other than that......
Old Apr 6, 2011 | 10:23 PM
stevelonewolf
LoL! It's all good.. It is easy to do. Just put the three bearings in a little ziplock baggie. There's a snap ring holding the two pieces sandwhiching the three bearings together.
2007ELECTRICGLIDE
Apr 30, 2011 08:24 AM
EasyGT
Apr 4, 2011 06:00 AM
pope924
May 21, 2010 07:50 AM
mmontgomery
Sep 7, 2007 10:48 AM
carguy9497
Oct 7, 2006 11:45 PM
