Looking for harley riders' ingenuity
Old Apr 6, 2011 | 09:57 PM
oakleaf's Avatar
oakleaf
Post Looking for harley riders' ingenuity
You know the bolt on top of the rear fender that holds the seat down? The guy who I bought my springer from didn't quite know how to put it back together after he bought a new seat so the area around the hole is damaged. It's damaged to the point where I can't ride a solo seat because the paint is chipped off as far as an inch from the hole. I've seen some rides with a round plastic insert/button that goes in the hole but I'm not about to go looking for an insert that's 2" in diameter. I'm hoping some of you guys and gals may know of a cool and creative way to cover up this blemish. I'm open to any and all ideas!
Old Apr 6, 2011 | 10:02 PM
av8or's Avatar
av8or
What about a fender bib?
Old Apr 6, 2011 | 10:09 PM
Kowan's Avatar
Kowan
I'd ruff up the damaged area and clean it with some acetone before hitting it with some primer. Otherwise, it will get worse and rust under the undamaged part. Then you can try to find a cover.
Old Apr 6, 2011 | 10:10 PM
JIMSFBL's Avatar
JIMSFBL
+1 on the bib
Old Apr 6, 2011 | 10:17 PM
brettnbama's Avatar
brettnbama
what these guys said.....fender bib is probably the only thing
Old Apr 6, 2011 | 10:20 PM
oakleaf's Avatar
oakleaf
I looked up some bibs and it looks like they might not quite cover up the damage. I think it'll pop out from under the back of the bib. If only the damage was toward the front! But primer is definitely a must.
Old Apr 6, 2011 | 10:22 PM
lo-rider's Avatar
lo-rider
Pillion pad.
Old Apr 6, 2011 | 10:24 PM
JIMSFBL's Avatar
JIMSFBL
I can't tell from your signature pic, but does the fender match your tank color? Can you post pics of the problem area?
Old Apr 6, 2011 | 10:30 PM
Kowan's Avatar
Kowan
If it's a stock paint job, I'd look through their paint wizard for repairing the damaged area.
http://www.colorrite.com/
Old Apr 6, 2011 | 10:34 PM
Rakthi's Avatar
Rakthi
+1 and if it's still noticeable maybe get a nice pinstripe graphic done on the damaged area
