Speedo Quit
Old Apr 12, 2011 | 03:04 PM
Poacher13's Avatar
Poacher13
Default Speedo Quit
Was riding around town today running some errands. Everything was
working fine. Stopped by my wifes work to say hello. When I left the
the speedometer had stopped working.
I have a 2004 Softail FSXT. Can anyone let me know how to check what
the problem is. If its the speedometer itself or if its something else. I
don't want to just replace the speedometer and hope thats it. Would
like to figure it out and only replace one thing. Not replace everything
hoping to find what is wrong.
Thanks.
Old Apr 12, 2011 | 03:07 PM
Mr. Pick's Avatar
Mr. Pick
When I lost the speedo on my Road King it turned out to be the "accessory" fuse that was blown. Might check your fuses, if you haven't already.
Old Apr 12, 2011 | 08:42 PM
cwsharp's Avatar
cwsharp
It isn't a big deal to change out a speedo so find a buddy who has the same model series and year that you have and borrow his speedo to see if it works. If it does, then you get to buy a new speedo. If it doesn't, then you get to chase gremlins, starting with the ignition switch and the wires from the ECM.
Mine failed at about 35k.
P.S. It doesn't mean anything if the speedo does the WOW test. It still can be bad.
C#
Old Apr 13, 2011 | 05:18 AM
Blk and Chrome's Avatar
Blk and Chrome
Ck the speed sensor in the trans too
Old Apr 13, 2011 | 12:21 PM
poppavein's Avatar
poppavein
This is the first thing I would do. They collect metal and need to be wiped off occasionally.
Old Apr 13, 2011 | 05:24 PM
handyhoward's Avatar
handyhoward
Wow!!! The first thing that I would do is check under my dash and make sure all the connections are clean and have dielectric grease on them... time for pm anyway. Check all your fuses as well.
Old Apr 13, 2011 | 06:18 PM
MCSarge's Avatar
MCSarge
As posted check the speed sensor and all the wiring connections and fuses. Are you running the stock ECM or a thundermax?
NickSchoff
EVO
Sep 19, 2023 11:39 AM
TSheff
Apr 22, 2014 06:56 PM
cgtrigg
Sep 25, 2012 01:22 PM
lt1tyrell
May 26, 2010 01:55 PM
cravej1
Apr 6, 2010 12:40 PM
