No... that's another reason I don't care for the HD Tourers..
I'm 6'2" and would get cramped on them riding around town..
I like my forward controls...
Still doing a lot of wiring. Here's my Relay setup for going from the NT single headlight to Duals... passing thru hot wires directly from the battery and using the orig. headlight wiring to trip the relays.
I remember doing a dual automotive horn setup with an automotive relay on my previous bike. I understand the need for the relay to take the power (with a suitably sized wire from the bat) due to the higher load, which then turns the stock switch wire as a signal to the relay, but I don't understand why you have dual relays. Can you explain why the second relay? Is it just simply 1 relay for high beams and 1 for low beams from the high beam switch? Did you put an inline fuse on your bat wire?
Well I can tell you put alot of work into it. You did alot of thought into planning it and I for one think it looks well built. It doesn't look cobbled together. Well done.
Right.. one relay is for the low, the second for the high beam.
Could have had the low beam pass thru the center connector (87a) of just one relay,
with the high beam switch closing the relay and switching to high beam.. but I preferred to use two relays.
And yes, I'm putting a 15 amp fuse between the battery and the relays.
