Cams
Old Apr 16, 2011 | 04:49 PM
cliveh's Avatar
cliveh
6th Gear
Default Cams
I have a 01 88" train running slash cut pipes stock carb with s/s high flow air cleaner.
What are the best cams I should run??
Old Apr 16, 2011 | 07:07 PM
roadkingharry's Avatar
roadkingharry
Depends on where in the RPM range you want the power and how much money you want to spend. I put the Andrews 26 in my 95" build, good midrange cam. With head work, V&H 2-1, it ran me $1400. You could do a cam only for about $400 - $500 if you DIY. Then there's the chain tensioner/camplate/oil pump issue that you should deal with.All goes back to budget.
BJFLHT
Jun 3, 2011 12:20 PM
swampking
Exhaust System Topics
Aug 9, 2009 05:48 PM
strange1
Jan 28, 2009 10:27 PM
shekmark
Aug 7, 2008 02:32 PM
harleymark
Sep 5, 2007 04:05 PM
