HELP !!!... PC III Map for 07 FLSTF???
By the looks of what they are posting Dynojet has to use an O2 sensor eliminator. Do the 07's have O2 sensors? When hot rodders started putting EFI Chevys in their cars, they wanted to eliminate all of the "EPA" stuff from their cars. Now they don't... once they learned how to really set one up. I am putting an LT-1 in a '75 vette... and I will have 02 sensors, among other things. It is a good thing, I think, to be able to run in closed loop if you are going to do anything other than 1/4 mile runs.
Just my $0.02...
C#
To me eliminating them is like a step backwards and puts it in the same class as that of a very fancy carb. Eliminating the O2 sensors kills its ability to monitor the engines output and change things to suit changing conditions. Without the O2 sensors the entire system is nothing more than a more sfficient, very expensive, very high tech carb, and instead of changing jets you change maps.
Somebody is supoposed to be making a wide band sensor upgrade for HD's Delphi system, but I don't remember who it is right now.
If anyone knows who it is, I would like to see what they are making, and how it works. Done properly it would be the perfect upgrade.
