wider tire ?
Old Apr 21, 2011 | 03:54 PM
softail 2003's Avatar
softail 2003
6th Gear
Default wider tire ?
Hi, i'm almost new to this site and i don't know very much about Harley.
I remove the carb and remove all possible screw and the bowl and boil it in vinager for 1 hour and reassemble, run like new. I also change the starter for a 1.4 kw instead of the 0.8 kw from hitachi from the factory.
I like the style of my bike but i would like it more with a wider tire. I have a softail custom 2003 with a 1340 1988.
The frame is a replica so where can i go from there ? thanks
Old Apr 21, 2011 | 04:02 PM
hspring03's Avatar
hspring03
post picture of the bike..
Do you want to change out the swingarm and go bigger than 200, or just go as wide as the current set up allow..
Most likely on an evo frame, depending on the fender you can go 150 or 160 maybe 180
Old Apr 22, 2011 | 07:30 AM
handyhoward's Avatar
handyhoward
I think your stock rear wheel is 16 x 3... if so max recommended tire width is 130. If you change out the wheel to a wider wheel, the max size tire that can fit your fender without any mods is a 160.
Old Apr 23, 2011 | 07:18 AM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
If you have a stock rim you can stuff a 150 under the fender, possibly a 160, but that is it.
Drew
Old Apr 24, 2011 | 02:46 PM
dlsmith82's Avatar
dlsmith82
While we are on the subject, does any one know the largest tire size I can run on a stock 1990 FXRS? It looks like I have about .25" clearance to the belt and no problems on the right side.
jb1023
Mar 3, 2021 08:24 PM
gonzalespop
Dec 2, 2016 09:45 PM
Disgruntled-Inc
Jul 6, 2016 08:31 AM
bladeguy
Oct 5, 2010 08:54 PM
2000fxdwg
Mar 5, 2007 09:53 AM
