oil change
Old Apr 24, 2011 | 09:14 AM
rockerz's Avatar
rockerz
Default oil change
What oil is the best to use?
I presume it's best to use the Harley oil filter?
Old Apr 24, 2011 | 09:24 AM
TheNameIs"B"'s Avatar
TheNameIs"B"
Getting ready to do this myself. I plan on using Mobil 1 V-twin 20w50 in Engine, Mobil 1 75W90 in Trans, and still up in the air for the Primary, maybe just a regular non-synthetic 10W40. Some say not to use the HD stuff, lots of metal flakes in the oil! Good luck, this will likely be moved to the oil Tech area. Hours of enjoyment and confusion there!
b
Night Stalker's Avatar
Night Stalker
This is a LONG debated question... Good luck on this one!
I use Amsoil with the HD filter, and I love it.
Bel-Ray in the Tranny.
My .02!
Old Apr 24, 2011 | 10:38 AM
WVNightrain Rider's Avatar
WVNightrain Rider
best oil is probally the most talked about topic.
I use Red-Line in the primary and tranny, currently using amsoil in the engine but will change to Mobil-1 next time due to the price and Wal-Mart and Advance Auto stocking it.
There are hundreds of sites out there that compare oils and say one is better then the other, the thing I find funny is the fine print "Sponcered by ******" now how fair is that.
The fact is most don't abuse their engine like a pro race driver and the typicial rider just enjoys the drive from point a to point b or bar to bar so any good quality should be fine.
My recommendation would be synthetic though due to it's higher heat rating with the air cooled engine.
Old Apr 24, 2011 | 10:40 AM
razorback84's Avatar
razorback84
I just did an oil change yesterday and used 2.5 qts of Redline and the standard black HD oil filter
Old Apr 24, 2011 | 10:48 AM
Soft06's Avatar
Soft06
Redline products in all 3 holes for over 30K....good stuff.
fcsallan's Avatar
fcsallan
I use standard dino 20w-50 in the primary, Mobil One 15W-50 (not v-twin) in the crankcase and 75w-90 Lucas in the trans.
Any oil can be used in the primary, as its only real function is minor lubrication and cooling. Just make sure there are no friction additives in it.
The bottom half of the circle noted at arrow 4 should be blank if the oil is good to use in the primary. This is the reasoning for the "V-Twin" notation on the Mobil one oils. They do not contain friction modifiers. However standard Mobil one does. Our engines can utilize the advanced friction fighters but the clutch cannot. Hence why I use standard Mobil One in the engine and standard Dino in the primary. You could also use Syn in there but it is such a light duty oil, there is little benefit and I would rather spend my money elsewhere.
Trans has never shifted smoother nor been easier to get into neutral since the add of the Lucas.
Old Apr 24, 2011 | 10:50 AM
watchluvr4ever's Avatar
watchluvr4ever
Just buy a reputable oil that meets Harley specs and be done with it! My Step-Dad's best friend has a shovelhead with over 75k miles(probably closer to 100k now) when he tore apart the motor everything was still within factory specs. He told me he has only used or will ever use just regular Harley oil. This topic is debated on every auto forum on the net.
Lucero1
"The Florida Crew"
30
Mar 22, 2012 09:34 PM
dynafan68
May 5, 2010 12:48 PM
bbqbrisket
Jan 24, 2010 07:12 AM
JW1200
Oct 8, 2008 06:39 AM
KBFXDLI
Oil Archive (no new posts)
Mar 29, 2008 07:42 AM
