Intake bolt is all bunged up and seem to be siezed. Allen head wont bite in it and dont seam to get a good bite with vice grip with enough space to move it any to losen. Does any one have any ideas as to what to use to remove it? all butthis bolt is out. sorry for blurry pic
You might be able to fit a bigger torx socket in there, or cut the head off, remove everything thing , then put a pair of vice grips on the stud or double nut the stud. That sucks dude, or maybe weld a regular bolt to the head there. good luck
maybe run the motor until it is hot then smack the end of the bolt with a drift to shock it loose then try the vice grips while the motor is still hot.
One has to be careful when putting steel bolts into aluminum heads etc use never seize or the steel and aluminum will eventually seize together, malox works well for never seize.
I used this for the reason to buy a new tool. I have been wanting a dremmel for some time lol. it took 2 disks to cut it off sliped the clamp off stud cut a slot in it used the screw driver to get it out. whatever locktite the builder used was so hard it jammed in the hole in the clamp and that was caused it to jam up. new dermmel 50 bucks 4 new bolts $2.94 at Ace (harley wanted $12 for bolts and wouldnt be here for 3 days) riding this pig priceless (RAIN GO THE F@#K AWAY LOL)
I had a stuck bolt the other day. I couldn't get it to budge even with a torque wrench. Ended up stripping out the head of the bolt. So I busted out the torch and I heated the bolt up, not the part it was in. Once it got red hot I heard it POP and vice grips easily removed the stuck bolt.
You only want enough heat so it transfers to the threads, but don't heat the part, heat the bolt.
