Deluxe Wheels
Old Apr 30, 2011 | 09:41 AM
eglinski's Avatar
eglinski
Default Deluxe Wheels
Can someone tell me for certain, if wheels from a 2009 Deluxe, w/pulley & Rotors (front and rear) will fit on a 2007 Deluxe? thanks
Old Apr 30, 2011 | 10:03 AM
t stone's Avatar
t stone
Just check bearing size. The 07 has 25mm front bearings and the rear has 3/4" bearings. I have a set of 07 wheels im getting rid of less the pully.
Old Apr 30, 2011 | 10:33 AM
aquaelvis's Avatar
aquaelvis
I tried to put 09's on a 04 and could not. (without custom spacers, etc) I was told the 08's and up won't fit any others. I sold the 09's to a guy who was putting an 08 back together and he told me the dealer said the same thing.
Don't know it it is true, but that is what I have heard.
The bearing size isn't a big deal as the races are the same you just need to change the bearing.
Get T-stone to give you a deal on his, be a lot easier. (I ended up finding a set of 04 wires in a buddies garage, the dealer took them off before he picked up his bike, that was an easy way to do it!)
Old Apr 30, 2011 | 11:19 AM
oct1949's Avatar
oct1949
thinking in 08 or09 they went to diff shaft size.
Old Apr 30, 2011 | 11:33 AM
BLKnCHRME09Deluxe's Avatar
BLKnCHRME09Deluxe
09' are 25mm front and rear
Old Apr 30, 2011 | 11:43 AM
eglinski's Avatar
eglinski
Thanks to all, I have seen now that the rear is totally different, the hub is longer and the swing arm looks wider.
I'm still thinking the front will fit, my 07' has 25mm axle.. and the HD website shows all the front custom wheels in Softail, will fit 2000 and up, the chrome front wheel spacer kit is the same # as well (2000 and up)
Shane T
Wheels/Tires
Dec 17, 2017 04:34 PM
Shane T
Oct 3, 2016 08:03 PM
Pnut327
Apr 24, 2015 01:45 AM
ramhunter9
Feb 22, 2011 07:55 AM
jcoers
Sep 12, 2008 11:39 PM
