oil blowin out thottle body then air cleaner
Old May 2, 2011 | 07:39 AM
Bsod's Avatar
Bsod
Question oil blowin out thottle body then air cleaner
I run a 117 " engine high compresssion engine and I got blow by commin out the air cleaner, not a whole lot but enough to be irritatting along side the rest of the engine, oil tank mainly. What causes it do you think and is there and easy fix? Or is it normal for what I'm running? Thanx for any input.
Old May 2, 2011 | 08:14 AM
cwsharp's Avatar
cwsharp
How many miles are on the engine and how often do your ride it. High miles (for a performance engine... say 25k) or low use = blowby on a harley. If you go for a long ride and then clean up the air cleaner and then go for a ride the next day, if it clears up then there's nothing to worry about.
C#
P.S. That's what that spot between the lifters is for on a Harley... to catch the oil running out of the air cleaner. <grin>
Old May 2, 2011 | 11:09 AM
Blk and Chrome's Avatar
Blk and Chrome
the breathers in the rocker boxes, not draining the oil out TP has a set with an improved breathing system to get rid of this
Old May 2, 2011 | 08:21 PM
Bsod's Avatar
Bsod
Thanx for the help fellas.
Old May 2, 2011 | 08:27 PM
Blk and Chrome
Mine did that last year and just redid the breathers and fixed the issue.
Old May 3, 2011 | 06:51 AM
Bsod's Avatar
Bsod
Mistake and can't figure out how to delete.
Old May 3, 2011 | 06:53 AM
hspring03's Avatar
hspring03
Double check the oil level.... Too much oil will cause blow by
Old May 3, 2011 | 10:55 AM
nikonf8's Avatar
nikonf8
Default oil
ditto on that last post most common reason for this type of blow by is over filling with oil
Old Oct 16, 2011 | 03:41 AM
Bsod's Avatar
Bsod
Real sorry to be getting back so friggin' late on this.... Who is the "TP" you mentioned? Thanx
Old May 12, 2012 | 01:42 PM
Bsod's Avatar
Bsod
Bump please, still don't know where to find "TP"
PS: oil level is good
