For those lowered Deluxe/Heritage Fork lowering
Old May 4, 2011 | 11:22 PM
ssrgeoff's Avatar
ssrgeoff
Default For those lowered Deluxe/Heritage Fork lowering
I tried searching multiple times so forgive me if this has been discussed before. Is everyone dropping the front the full 2" or maybe more? I have the fork lowering kit but missing the additional 2 top out springs so I would only be able to get 1" lower. Thinking of purchasing another kit but this time going drop in so it's easier to raise/lower down the road. For the drop in kit what size PVC are you running? I see it says 3.00 in the directions but I don't know if that is stock, -1" and how much to cut for -2" thanks for any help!
Old May 5, 2011 | 07:21 AM
Malingerer's Avatar
Malingerer
I am running the progressive drop in kit with the full 2" drop.Cutting the PVC spacer at 3" as per the instructions will give you the full 2" drop.I would not go any lower then that.I also have recently added the Ricor Intiminators to my front forks.They smooth out the front end and offer a very confidence inspiring feeling to the overall handling and braking performance of the bike.Since you are going to be in the forks now is the time to do it .If you can swing them.If you do add them you have to cut an additional 5/8 th's of an inch off the pvc spacer(this is how much room the Intiminators take up in the fork tube).This will retain the full 2" drop and proper geometry and handling of the front end.The Ricors do not cover lowering kit in the instructions they provide.I spoke with Brian at Ricor and he provided me with the info listed above. Mal
Old May 5, 2011 | 07:23 AM
Malingerer's Avatar
Malingerer
Here is a pic of what they look like
Attached Thumbnails For those lowered Deluxe/Heritage Fork lowering-dsc01846.jpg
Old May 25, 2011 | 03:10 PM
mtblazin's Avatar
mtblazin
do your pipes scrap with your bike lowered that much
ARTZWAKEN
May 28, 2016 08:16 PM
kickstarter1340
EVO
Apr 6, 2015 03:56 AM
mike06train
Mar 24, 2010 09:58 PM
rounder
Nov 9, 2009 01:41 PM
ShooterSteve1953
Mar 15, 2009 09:58 PM
