k so here i sit. I have read the info on setting rockers the torque and all that. the only question i have is how do i check the rocker drag. Do i need a special tool. I would like to take mine apart and clean them this weekend but if i cant figure this out than there is no way i will touch it till i know how to do all the steps thanks guys.
I know it will come up so. its an 03 train with mid usa front end
reason i want to do this is when i torque down the axel it binds the rockers up and thus making my front end rigid if i loosen off the axel nut a bit it works proper. Spacers are right just spent the night working around them. maybe im wrong but im torqueing to 65lbs.
Trying process of elimination
Thanks
