ohh snap @ 75mph
Old May 6, 2011 | 11:32 AM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Did you have poly bushings in the trees?
Drew
Old May 6, 2011 | 01:15 PM
SMF's Avatar
SMF
aGRADE 8 LOCO
Old May 6, 2011 | 01:34 PM
meatsack's Avatar
meatsack
That's a "big eyes, brown shorts" moment...
Glad you're okay.
Old May 6, 2011 | 01:45 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Show us the markings on the head of the bolt please.
OEM riser bolts are Grade 5.
I don`t think the failure is from overtorque, a grade 5 bolt would probably pull the threads out of the riser before the bolt was damaged.
The bolt failed at the threaded part, but the threaded part should have been fully into the riser.
My guess is that it is not the correct bolt, or not enough torque.
Old May 6, 2011 | 01:51 PM
oct1949's Avatar
oct1949
With the small dia on the bottom of the riser and If U have Apes.. then Ur putting a lot of stress on the riser bolt every time U get on and off the bike from the height of the bars.
The taller the bars the more stress thats applied..
I am also thinking its more from that than over TQ the bolt itself.
Old May 6, 2011 | 03:16 PM
dyebartdie's Avatar
dyebartdie
damn you better get that fixed by tomorrow!
Old May 6, 2011 | 03:27 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
What's the big deal.....it's not like both of them broke..... j/k
Old May 6, 2011 | 08:37 PM
Nameless.'s Avatar
Nameless.
Here are some more pics. The bolts are grade5 and I am replacing them with some grade8 bolts. As for the bushings, they are poly and iam replacing them with new ones at the same time..
Old May 6, 2011 | 10:33 PM
marines267's Avatar
marines267
Default Bolt
Originally Posted by NorCal Dog
looks to be a cheap cad plated pot metal bolt, replace it with a Grade 8 fastener my friend
glad to hear that you lived to tell the tale
Replace it with a Lawson tough toq much better than a grade 8
Old May 7, 2011 | 12:43 AM
j1mmy's Avatar
j1mmy
that really sux..i had a riser bolt fall out on a stretched springer chopper once..i was pulling into a bike shop,the bars went sideways..i still dont know how i saved it..it still freaks me out when the bars move from the bushings flexing
