Removed Gas Gauge
Old May 15, 2011 | 10:15 AM
Keithhu's Avatar
Keithhu
Originally Posted by dansax
I read about your troubles in another thread. So what you're saying is the old gas gauge must be connected for the new separate speedo to work. I still say there might be a way around this. This is what pisses me off about Harley. Seems like everything is designed half assed. You can't pull the wires through the hole after disconnecting the plug for the gauge. So you cut them and then you run into more problems.
Not the old gas gauge necessarily, but *a* gas gauge.
Cutting the wires didn't really cause any problem, I cut them on the gauge side, at that point its already disconnected.
Old May 15, 2011 | 10:17 AM
Keithhu's Avatar
Keithhu
In reality this is really just about $100, at a certain point it's just too much trouble to be worth all the time it takes to bake up and install complex home remedies.
Old May 15, 2011 | 10:47 AM
NoRegerts's Avatar
NoRegerts
I'm just going to add an LED gauge on that side. If I ever decide to repaint the tank I'll fill it in with metal and be done all together, but for now an LED gauge will be fine. Besides, I like the shanzy colors on my new gauge and the fuel gauge on the new speedo/tach I can actually trust.
Old May 15, 2011 | 11:13 AM
SpicOfTheDevil's Avatar
SpicOfTheDevil
i'm really happy with the flush mount kit...would get the speedo/tach for the tach function
LJL4
Jul 28, 2017 07:43 AM
dansax
Aug 19, 2014 09:34 PM
JonGolden
Jun 3, 2014 11:23 PM
Striker951
Feb 27, 2014 12:02 PM
mibeaulieu
Jul 24, 2012 10:50 PM
