No, I have the stock trees. You can check out my Rocker thread below, it has all the info.
thread where??? I went to your page and saw a build you had on a rocker with numerous parts but didnt see anything with triple tree or forks etc.. so you used the original rocker front and just changed the spacers?
No parts are listed because yes, stock front end and yes, new spacers or turning down the originals will be needed. The fender was my biggest issue, I had to have one custom made because I wanted to keep the wheel/tire offset (like stock), not centered between the forks. That info is in the thread also..https://www.hdforums.com/forum/softa...od-thread.html
so just grind down the spacers correct ? When the stock wheel is mounted I see that it is more towards the left side (looking at the wheel front view)(opposite side of the caliper).. its not straight in the middle.. correct .. also on the duese center console I see that you have the one with 2 bolts that mount down by the seat.. and i only see one bolt on the bottom of mines ? I have an 08 rocker...
