Need Some Help Pleeeez
Old Jun 6, 2011 | 08:02 PM
cpiad's Avatar
cpiad
Account Closed
Originally Posted by irunaumuck
Pinched wire maybe?
Plus one.
Old Jun 6, 2011 | 09:34 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
When you take off the switch housings you should always put a piece of cardboard in between the brake lever and the and the housing. You might not have broken your switch. Did you add new levers? Sometimes the tolerances on the levers are a little different and this can cause the same problem. Jiggle the lever a little and see what happens to the brake light. I have also heard of people threading a screw into the switch where the nipple is if it is broken off. The switch is $60.
My switch died while intact. Just old age I guess as the bike is nearly 10 years old.
Drew
Old Jun 7, 2011 | 01:50 PM
VA_Grumpy_Biker's Avatar
VA_Grumpy_Biker
You should be able to fix it yourself. Read the manual and it shows how to shim the handle so you don't break the switch.
toadster911
Electrical/Lighting/Alarm
Oct 4, 2017 10:18 AM
Firechaser1141
Sep 9, 2013 10:04 PM
iupsig97
Apr 16, 2013 07:50 AM
b duncan
Aug 18, 2010 06:34 PM
fastjoe
EVO
Oct 19, 2008 08:09 AM
