Harley Fatboy Passenger Peg question
Old Jun 14, 2011 | 10:33 AM
silentstorm16's Avatar
silentstorm16
Default Harley Fatboy Passenger Peg question
Hey I own a 2006 fatboy. I recently placed passenger pegs on my bike. the only problem I'm having is whenever I ride the clutch side peg come down. I tried tilting the pegs back but now both pegs come down. Does anybody have a trick from keeping them from coming down or should I just deal with it thanks.
Old Jun 14, 2011 | 11:37 AM
hspring03's Avatar
hspring03
Theres a clip that goes between the mount that keeps them from falling. Did you put that clip in?
Old Jun 14, 2011 | 11:48 AM
silentstorm16
Yeah it's a rusty looking clip. They keep coming down due to the vibration from the bike.
Old Jun 14, 2011 | 11:52 AM
fcsallan's Avatar
fcsallan
They are made of spring steel. You might have to get new ones if they don't have the arch in them that keeps them from letting the pegs flop. You can try to put a bend in them, but I suspect it won't be easy.
Old Jun 14, 2011 | 11:54 AM
CJinNH's Avatar
CJinNH
The clip should have a curve to it causing tension, probably could curve it a bit more by crimping if things have loosened up.
Old Jun 14, 2011 | 11:59 AM
Tracker56's Avatar
Tracker56
If you did put it the spring clips, are they Harley one or aftermarket? I have found that many of the aftermarket clips are thinner and don't enough arch to maintain adequate friction on the peg.
Old Jun 14, 2011 | 02:52 PM
eagles's Avatar
eagles
When i put aftermaket pegs on the rear (they are much heavier than stock) mine would fall down aswell. Just put the clip in a vise and give it a little bend with plyers no more loose pegs.
Old Jun 14, 2011 | 08:51 PM
cpiad's Avatar
cpiad
Account Closed
Be sure the spring tab is inside of the clevis.
Windseeker
Jun 2, 2019 07:21 PM
black1125
Aug 2, 2013 11:30 PM
jquig80
May 23, 2013 08:02 PM
Kojax
Jun 3, 2012 05:55 PM
F34R
Jul 19, 2011 04:09 PM
