Handlebar swap help
Old Jun 16, 2011 | 02:11 PM
ezcomezgo's Avatar
ezcomezgo
Default Handlebar swap help
do i have to cut and splice electrical from under the seat to get a narrow end for feeding through new handlebars? or is there a trick to the disconnect that allows grip end components to feed through the bars? yea, i did a search, but came up empty with "handlebar electrical disconnect".
Old Jun 16, 2011 | 02:19 PM
XARAN's Avatar
XARAN
Disconnect under the gas tank at the block or easier since you usually need to lenghten the wiring to go through the bars is just cut them just under the gas tank feed through the bars add extentions as needed and solder and shrink wrap, youll never know the splice is there.
Use a vacumn cleaner and a cotton ball tied to a string to feed through the bars and then tie to the wiring and pull
Donzie
Jan 10, 2015 10:20 AM
scottystreetbob
Mar 30, 2013 11:29 AM
run2bfit
Mar 26, 2009 07:15 PM
DrPlastic
Nov 10, 2007 10:22 PM
dmac1968
Aug 26, 2007 08:00 AM
