softail deluxe ground
Old Jun 21, 2011 | 07:25 PM
prost34's Avatar
prost34
Default softail deluxe ground
ok,check engine,battery lights on again,,,checked my code(thanks drew), battery low voltage,put a brand new battery in her still there,i removed the oil tank and primary cover to paint it black a couple days ago,not sure if i put the ground back where it was,did not pay attention,i grounded it to the two bolts that holds the t clamp for the two wire harness,anyone have a pick with the seat off?,bare with me,new to harleys,,thanks,,,
Old Jun 21, 2011 | 08:17 PM
jlasoftail's Avatar
jlasoftail
Sounds like you put it back in the right place, but make sure the connection is tight and clean. Even if you didn't put it back in the same place, it should be fine as long as you are making a good connection to the frame. Don't know if you checked it or not, but maybe a regulator problem?? Anyways, start with double-checking that you have good battery and ground connections.
The Silver Viking
General Topics/Tech Tips
14
Oct 16, 2015 03:12 PM
wrussi
Dec 28, 2014 11:48 AM
Michael Gamboa
Exhaust System Topics
Jul 27, 2013 03:03 PM
Michael Gamboa
Jul 24, 2013 08:06 PM
HogDeluxe
Oct 30, 2007 06:37 PM
