Please Help... No Brake Light
Old Jun 23, 2011 | 04:11 PM
95yj's Avatar
95yj
Now, why isn't the rear brake setting off the light?
Old Jun 23, 2011 | 06:28 PM
Vic Bronco's Avatar
Vic Bronco
The rear brake wasn't setting of the brake light because it was already lit up from the switch on the front brake not being depressed. The way the switch is set up, when the brake is off the switch is pushed in, when you pull the brake lever the switch is released and the brake light goes on. If the lever isn't lined up properly with the switch, it doesn't push it in at all, resulting in the brake light staying on. If you don't look closely it just looks like your tail light is on and your brake lights don't work.
denmaz
Electrical/Lighting/Alarm
Sep 4, 2015 09:46 AM
mballard
Shovelhead
May 19, 2012 05:33 PM
iltbone1
Sep 19, 2011 12:18 PM
cnewty
Jun 23, 2007 01:29 AM
SIDEWAYZ50
May 23, 2006 08:32 PM
