oil pressure
Old Jun 25, 2011 | 05:25 PM
ONEEYE05FLSTC's Avatar
ONEEYE05FLSTC
Default oil pressure
well here;s a good one for you; all of a sudden, out of the blue my heritage started having oil pressure issues. it was running fine, just like always the last 76k miles then one day last week i stopped for gas and when i started back up again the oil pressure was only 10 psi. i drove it about five miles and still no improvement. i stopped and checked to see if oil was returning to the tank and it was but it was also foamy. i let it cool down about 50 degrees and when i started it up it went to 40 psi and stayed there for the next 150 miles. yesterday it did the same thing.
today i drained and cycled out the hd 20/50 dino oil and changed filter. this time i put in redline syn 20/50. took for a test run on fwy. started out at 20 psi then moved up to 40 and stayed there. no foaming either.
has anyone had a similar case?
email me at harleysrule69@yahoo.com
thanks
Old Jun 25, 2011 | 05:28 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
What year is your bike? Any mods?
Drew
Old Jun 25, 2011 | 10:14 PM
harleycharlie1992's Avatar
harleycharlie1992
Unofficial HDF Chaplain
possible sticking oil pressure relief valve? hard to say now that its working
Old Jun 26, 2011 | 06:31 AM
FroggyFatBoy's Avatar
FroggyFatBoy
from my experience with any fluid that is foaming means that is low and causing what is known as areation of the fluid..
did you check the level ? if it was ok, theres probably a seal leaking on the suction side of the pump.
Old Jun 26, 2011 | 07:31 AM
Tom84FXST's Avatar
Tom84FXST
+1..............
Old Jun 26, 2011 | 07:38 PM
ONEEYE05FLSTC
Default Foaming / low oil pressure
dr v-twin;
it's an 05 heritage; original motor was an 88b; rebuilt under extended warrantee 2k ago by independant shop; harley sent wrong parts so now it's a 96b.
think i'll pull the cam cover and check for foriegn objects; if i don't find any then i'll just run it until it dies then buy a goldwing.
Old Jun 27, 2011 | 10:04 AM
95yj's Avatar
95yj
We'll pretend that you didn't say that or even think it. . .
Old Jun 27, 2011 | 12:43 PM
oct1949's Avatar
oct1949
dr v-twin;
I didn't know an Indy could do warranty covered work on a Harley..
What parts did they install to make an 88 in'er into a 96'er?
jmltinc
EVO
Dec 23, 2010 07:20 AM
Klor
Jun 4, 2010 10:55 AM
mr39
EVO
23
May 10, 2010 12:36 AM
Xmoto
Apr 25, 2008 02:19 PM
SURFOR Chop
May 2, 2007 11:29 AM
