Help!! Which Load Equalizer?
Old Jul 6, 2011 | 12:23 PM
scottiedawg's Avatar
scottiedawg
Default Help!! Which Load Equalizer?
Hey guys, I have an 08 cross bones that I have put the led bulbs in the rear and I just installed the heartland turn signal mirrors. I know I need a load equalizer, but which one do you guys recommend???
Old Jul 6, 2011 | 01:27 PM
purecountry13b's Avatar
purecountry13b
A memeber suggested this to me. Might help. Just seems like you would need two, which gets pricey. http://www.biketronics.com/products/...Equalizer.html
Old Jul 6, 2011 | 01:39 PM
tlb's Avatar
tlb
Did you try disconnecting the battery, hooking it back up, and using your signals? I did this when I installed the rear alloy art signals, the voltage corrected by itself.
Old Jul 6, 2011 | 05:00 PM
scottiedawg
Thanks purecountry I will look into that. But first I will try the tip from tlb...
Thanks guys....
Old Jul 6, 2011 | 05:20 PM
RocketRocker's Avatar
RocketRocker
I just bought the Illuminator III from badlands and its a plug and play load balancer....
http://www.badlandsmotorcycleproduct...cts/BETCSM.htm
Plus it will automatically convert your dual element signals into 3 way (run, turn, brake). Good luck.
Old Jul 6, 2011 | 05:48 PM
scottiedawg
Thanks for the heads up rocketrocker!!!!!
Old Jul 6, 2011 | 06:00 PM
tlb's Avatar
tlb
let the signal blink for a couple of minutes, to see if the load adjusts.
Old Jul 6, 2011 | 07:32 PM
j33ptj's Avatar
j33ptj
For the front lights I didn't need an equalizer, installed a Badlands for the rear!!
RJ
jambo1989
Jan 17, 2017 08:33 PM
DBLXX
2014-2024 Touring Models
Mar 1, 2014 10:11 PM
HDFan0611
Mar 14, 2013 12:30 AM
Partisanjager42@aol.com
Electrical/Lighting/Alarm
May 13, 2012 05:08 PM
Panthers65
Oct 29, 2010 03:52 PM
