Intermittent ignition problems
Old Jul 11, 2011 | 09:20 AM
FuelSlut's Avatar
FuelSlut
Stage IV
Default Intermittent ignition problems
Hey guys im having an issue with my 97 softail springer. Every so often the bike out of no where will just start skipping and lose all power then with what seems to be a click of a switch it comes right back. This happens at all different times, sometimes after riding for an hour sometimes after 15 minutes. I was told the bike has an Andrew's coil on it, does anybody know if the ohms should be the same as the stock coil? or any other ideas? thanks
Old Sep 18, 2012 | 07:57 PM
bigborebagger's Avatar
bigborebagger
5th Gear
Default Re: Ignition Skipping.
Same problem just started tonight. Loose all power except for turning the switch to accessories but no ignition. Then bang, everything is back. What was your problem. Weird !
Old Sep 18, 2012 | 09:37 PM
Jim Kraft's Avatar
Jim Kraft
Sounds like the main breaker to me. It is on the front of the rear fender on my 99 Softail Custom. They sometimes will get weak and overheat, and then after cooling a bit it will close again. Something to check anyway.
Old Sep 18, 2012 | 09:50 PM
QC's Avatar
QC
A couple friends have EVOs, one with a Crane ignition, one with a Dynatek(?) Crane outright broke and the Dynatek had an intermittent miss as you describe. Turned out to be heat related. Some transistor or such had gone bad. The thing would overheat and shut down. At least that was what I was told. Tracing part time electrical problems is a pain and expensive. Start with the cheap stuff 1st. Coils do go bad.
Old Sep 18, 2012 | 10:02 PM
soft 02's Avatar
soft 02
Has happened to me twice. I had corosion in the switch. Dis assembled and cleaned up.
Old Sep 19, 2012 | 07:55 AM
Rodzilla6's Avatar
Rodzilla6
I had a similar problem with my rocker and it turned out to be the start switch on the handlebar. Only 60 bucks to fix but a pain to diagnose!
Old Sep 19, 2012 | 08:14 AM
wtb3886's Avatar
wtb3886
Greetings Intermittent ignition problems
Have you searched for DTC codes, not sure if your bike has a computer or not, the problem may be with a connection to your computer cable under the seat loosing a signal and telling your fuel to shut off.
With the kill switch in the on or run position, press and hold the speed odometer in, then turn your main switch to the on position, the dials will perform a full sweep, turn loose of the speed odometer, does diag appear where your mileage is, if so press and hold for a second the speed odometer switch, when the diag goes away does letters appear. report back what you find.
JohnnyC
EVO
49
Apr 10, 2022 02:12 PM
roofer
EVO
14
Apr 26, 2009 06:20 PM
mmb617
Aug 23, 2006 08:14 PM
killdeer
Jun 8, 2006 11:00 PM
Popeye47
Mar 25, 2005 10:47 PM
