Stalling when driving
Old Jul 22, 2011 | 09:48 AM
arnieb's Avatar
arnieb
6th Gear
Default Stalling when driving
I have a FXSTI and driving down the road it will stall, I had it checked out at the local shop and they couldn't find anything wrong and of course it wouldn't do it for them. Any one have a clue on what this could be?
Old Jul 22, 2011 | 10:11 AM
hspring03's Avatar
hspring03
Does anything happen to the lights or speedo before it stalls?
It could be the speed sensor is dirty or failing..
But it could be a lot of other things too....
Old Jul 22, 2011 | 10:35 AM
arnieb's Avatar
arnieb
6th Gear
Default re:
No just stalls with no warning. The problem comes and goes.
Old Jul 22, 2011 | 10:40 AM
jdunn01's Avatar
jdunn01
I have heard of people getting a pin hole in the fuel pick up inside the tank that had similar symptoms. You may want to check that also.
Although I think most encountered it after the reach 1/2 tank and not when full.
Old Jul 23, 2011 | 10:11 PM
oct1949's Avatar
oct1949
Yep,, just had that done to mine.. at 33k miles. Every time I fill up she'd run fine for 100 miles or so.. then she'd start missing... fill up again and all well till another 100..
I didn't do a new filter as per my Indy and my conversation.. he said the filter will last longer than the recommended 25k that HD says it will.
True the filter prob will but the hoses prob wont anymore with the Ethanol gas we have to use and buy/.
The wrench that fixed mine said that since they switched to the Ethanol that a lot of Harleys now are having to switch out the hoses every 3-4 yr.
True the filter usually will go farther,,, but a pinhole in one of Ur rubber tubes inside the tank wont...
I went ahead and replaced everything inside the tank,,, about $150 in part and 2 hrs labor...
Bad thing was mine did it when I was over 500 miles away from home on a 5 day riding vacation...
Still IMO its better to do it at the 25k or 30k service than be sitting on the side of the road waiting to be towed in.
Old Jul 25, 2011 | 05:34 PM
arnieb's Avatar
arnieb
6th Gear
mine stalls out if the tank is full or low. will act up and then run good for awhile
Old Jul 26, 2011 | 05:04 AM
Lawaia's Avatar
Lawaia
2nd Gear
Check battery connections; ensure they are snug.
Old Jul 26, 2011 | 08:25 AM
arnieb's Avatar
arnieb
6th Gear
yea the battery connections are snug that was the first thing I checked. Could the ECU be bad?
Old Jul 26, 2011 | 08:54 AM
FreddyJ's Avatar
FreddyJ
Are you losing voltage when it dies?
Old Jul 26, 2011 | 10:05 AM
arnieb's Avatar
arnieb
6th Gear
no, she doesn't like to start when it is warm RPM's stay high for a while and also sometimes when I am idling at a stop light. when that happens I know she is going to want to stall when I try to gas on it.
DJ_Playaing
Harley Davidson Videos
Oct 29, 2016 12:56 AM
Foxster
May 27, 2010 08:49 AM
Freakofnature
Jun 29, 2007 01:21 AM
badbs101
Dec 12, 2006 02:13 PM
blazzinbird
Aug 11, 2006 01:59 AM
