Strange shifting problem???
Old Jul 25, 2011 | 12:29 PM
captainron62's Avatar
captainron62
Originally Posted by tlb
If it is not the clutch, I would check the bushing in the shifter arm, it is a common problem on softails. The bushing gets little dirt in it and the it makes everything feel weird to the point of not being able to shift.
Thanks for the tip! How do you like your big bore kit with the 203's. I just bought the same set up, gettin it installed in sept. Would love to hear some input.
Old Jul 25, 2011 | 12:33 PM
oct1949's Avatar
oct1949
just go back and talk to him....
Several thread in here a couple weeks ago about making sure to oil the shifting shaft that Ur shift levers go on.. Several members had a issue of shifting hard because of rusting in that area..
Find out if he adjusted the clutch and or the linkage. then go from there.
Old Jul 25, 2011 | 02:15 PM
jed1069's Avatar
jed1069
As said before I would first check oil level in Tranny to see if it has any or is too full. Then Look into clutch and shifter. Just ask you mechanic what he did and that will point you to items to look at.
Old Jul 25, 2011 | 02:37 PM
tlb's Avatar
tlb
I like the kit with 203s. I thin the thundermax also made a huge difference, from the fuelpak I was running. I have lots of power. even at 90mph I can twist the throttle and take off. I do not go 90mph often. I do ride regular at about 75-80mph on the turnpike, 75mph is legal. I never have an issue with needing more power.
Around town is has plenty of power unless I am at a really low rpm in 4th.
You should think about installing ti yourself, my wife an I did it in about 12 hours total, disassembled and assembled. It was really easy to install. I had the dealer press in the cams for me.
Old Jul 25, 2011 | 02:42 PM
captainron62
Thanks, I appreciate it. A buddy that builds race car motors and has done a few in the past is gonna help me. We both have some time off around labor day weekend, so thats when were gonna get er done. I cant wait, sounds like im looking for the same things as you, just more cruising power and some fun now and then.
Old Jul 25, 2011 | 04:10 PM
tlb's Avatar
tlb
Are you going to install the upgraded camplate, tensioners, and oil pump a the same time?
Old Jul 25, 2011 | 04:45 PM
captainron62
I as of now only have plans to install the Stage II kit as it comes from Harley. did you do those additions?
Old Jul 25, 2011 | 05:49 PM
tlb's Avatar
tlb
The spring style tensioners are a headache waiting to happen. I installed the upgrade.
rkc915
Aug 1, 2015 03:38 PM
ShrinerRider
Jul 18, 2012 12:08 PM
dtgman
Sep 12, 2010 12:38 PM
mankx
Aug 11, 2008 12:34 PM
Slakass
Nov 29, 2005 11:45 AM
