Stuck in 6th
Old Jul 17, 2012 | 07:48 AM
ShrinerRider's Avatar
ShrinerRider
Default Stuck in 6th
On the way home yesterday on the superslab as I approached my exit I realized my bike would not come out of 6th gear. I tried more pressure to no avail. I passed that exit and started basically kicking the crap out of the shifter and it finally came into 5th. No issues after that through the gears on the way home. Came in this morning and had no issues.
I ride a 2012 Ultra Classic with no mods. The bike had just came out of the 1,000 mile service where they switched me over to Amsoil.
Has anyne ever experienced this or heard of it??
Any ideas?
Thanks in advance!
Jason
Old Jul 17, 2012 | 07:53 AM
drukanfu's Avatar
drukanfu
You might have pulled your clutch in and waited to long to down shift, sometimes when you do this even in lower gears it can happen. If you want redo your clutch adjustment.
Old Jul 17, 2012 | 08:11 AM
Lowcountry Joe's Avatar
Lowcountry Joe
Don't know what Amsoil has to do with your problem but....
Anyway, check to see that the shifter is not hanging-up or rubbing on anything on the bike.
Was the 6th gear green led on the whole time? Did it feel for sure like you were still in 6th? At speeds below 60, that engine should have been lugging like the dickens.
Not sure if a mal-adjusted clutch could cause this or not...but worth checking to see if your clutch is properly adjusted just for grins.
Unfortunately, you can't depend on the fact that the 1000 mile dealer service produces a perfect bike. There are so may adjustments that they don't/won't check.
Good luck with finding out what caused the hang-up.
Old Jul 17, 2012 | 08:34 AM
ShrinerRider
I dont think the Amsoil had anything to do with it either, that was just the only thing that had changed. Yes, the 6th gear light was on the whole time. Thanks for the responses.
Old Jul 17, 2012 | 08:37 AM
mopar400's Avatar
mopar400
Heal shifter is for going up a gear. You can kick on it all day and never go down to 5th gear.
Old Jul 17, 2012 | 08:43 AM
ShrinerRider
Absolutely, hopefully you know what I meant, kicked the front! Thanks for the catch, I will edit it to reduce confusion!
Old Jul 17, 2012 | 08:44 AM
drukanfu's Avatar
drukanfu
Refer to my first post !
Old Jul 17, 2012 | 08:54 AM
ShrinerRider
Drukanfu, I am going to try to replicate it on the way home today, thanks for the help.
Old Jul 17, 2012 | 09:42 AM
TUCCI's Avatar
TUCCI
If it keeps doing it...I would inspect the shifter shaft at the tranny to make sure it's not acting up knowledge is power:
https://www.hdforums.com/forum/touri...he-tranny.html
https://www.hdforums.com/forum/touri...ift-shaft.html
https://www.hdforums.com/forum/touri...ift-lever.html
Old Jul 18, 2012 | 12:08 PM
Tinman265's Avatar
Tinman265
I had a couple of times my limited didn't want to down shift. Took 5000 miles for it to work itself out. Kept the clutch adjusted and switched to Amsoil 75w90 gear lube. I believe the clutch caused it must of the time.
smkauffman
Milwaukee Eight (M8)
19
Jul 21, 2018 02:00 AM
graphicdisaster
Mar 27, 2017 08:31 AM
Dirtbike
May 29, 2015 07:07 AM
surf256
Aug 15, 2011 07:57 AM
phipsi74
Jan 9, 2008 02:42 PM
