Bad vibration!
Old Jul 26, 2011 | 07:38 PM
Albritton's Avatar
Albritton
Default Bad vibration!
Got my bike back from star racing from getting dyno'd and now it has a terrible vibration. Feels just like a unbalanced motor..have y'all encountered this? What could it be?
Old Jul 26, 2011 | 08:10 PM
Wild Card's Avatar
Wild Card
most likely the sprung the counterbalance, the balance motor does not handle hard snapped acceleration and decel that most dyno tuners practice. 99% sure your tuner screwed the pooch
Old Jul 26, 2011 | 08:19 PM
djl's Avatar
djl
Could be if it's a softail but my money is on a tweaked crank; check the crank runout and report back.
Old Jul 26, 2011 | 08:20 PM
Albritton's Avatar
Albritton
So If that is what happened, what do I do now? Is it fixable?
Old Jul 26, 2011 | 08:24 PM
Wild Card's Avatar
Wild Card
I would contact them immediatly, yes fixable but bye bye rest of riding season. complete tear down to crank
Old Jul 26, 2011 | 08:37 PM
Albritton's Avatar
Albritton
I Told them before I left that it wasnt right. They said they would tear it down for a grand diagnose the problem and put it back together for another grand and the parts cost will be extra. I'm going to get it and take it to another shop. I won't be dealing with these people again
Old Jul 26, 2011 | 08:43 PM
djl's Avatar
djl
Albritton, IIRC, your bike is a 2001 Heritage? Sorry to hear of your troubles and it may seem like the end of the world but it's nothing time and money won't repair.
The early models had near bullet proof lower units; hot forged cranks and Timken bearing on the primary side of the crank. Any crank can be tweaked but the early models are less prone and can take more abuse than the '03 and later cranks.
The first thing you do is take the bike back to the tuner and put him on notice about the vibration and see how he reacts. Most tuners accept no responsibility for whatever happens to your motor once on the dyno but he needs to know that you know he screwed the pooch.
Next step is to open the cam chest, pull the cam plate and check crank runout at the crank pinion; .0015" is typical for the early models. When runout starts to exceed .006".007", you will start to feel the vibration and buzz in the bars and pegs. Once it exceeds .010", you will feel it at lower speeds. Once it gets above .015", everything starts to shake all the time.
If it is the crank, you are looking at pulling the motor, splitting the cases and sending your crank to Hoban Brothers for repair which will include servicing the entire lower unit and truing, balancing and welding the crank. I would send the complete lower unit for them to split, repair and reassemble; I wouldn't leave that for a dealer tech. Hoban will go through the lower unit and replace any bearings or bushings that need replacing and repair the crank. You won't have any worries about crank problems in the future.
If runout checks out, then, as someone has pointed out, the counterbalancers have been damaged. I am not sure but I beleive Hoban can repair them as well and can also lighten them and balance them better than the factory balance. If Hoban doesn't do it, Small Block Charlie does. It will be expensive but you really don't have any choice. I woudl not trust this work to a dealer. Let the dealer do the motor R/R but send the lower unit out for repair.
One last thing, you need to post your dyno results to settle the wager between me and Jeff in your Horsepower!!!!!!! thread. Welcome to the world of Harley performance where **** happens. Let us know how it goes.
Old Jul 26, 2011 | 08:57 PM
Albritton's Avatar
Albritton
I just posted them. Thanks for the info!! It was 77 hp and 92 ft lbs of torque! Im really upset about this whole situation
Old Jul 26, 2011 | 09:13 PM
Wild Card's Avatar
Wild Card
that's a nice torque figure for a stock bore TC88, that kinda tourque will cause **** to go wrong in bad hands.
Old Jul 26, 2011 | 09:25 PM
harleycharlie1992's Avatar
harleycharlie1992
Unofficial HDF Chaplain
more than likely somewhere you signed a waiver removing them from any damage done on the dyno. pretty standard practice. the dyno is a very violent place for motorcycle motors, not for the faint of heart. more than likely it is very internal and will be expensive, sorry to hear the bad news for you
