deuce headlight bucket
Old Aug 1, 2011 | 12:57 PM
04reddeuce's Avatar
04reddeuce
Default deuce headlight bucket
after my headlight bucket is tighten if I lift from the bottom the bucket raises then and when I let go it falls back into the spot where I set it. Is this normal or should it be mounted solidly with no movement what so ever. thanks
Old Aug 1, 2011 | 03:11 PM
AzDeuce's Avatar
AzDeuce
My headlight bucket flexes in the mount. I never had to adjust it since it was new.
Old Aug 1, 2011 | 05:08 PM
04reddeuce's Avatar
04reddeuce
ok, that's what mines does. Ever since I installed the led headlamp it doesn't want to stay. I've tried threadlock tape, lock washer with stock acorn nut and now Ive got a lockwasher with a hold tight nut.
Old Aug 1, 2011 | 08:29 PM
looneytune's Avatar
looneytune
Mine does the same thing. It won't stay adjusted and I have to pull the light up a couple times a week to keep it adjusted. The whole bucket isn't moving, it's the flexible mounts that's moving or bending. I guess I'll have to pull the headlight out and see whats going on inside. I thought I had bad steering stem bearings becuase I was hearing a clunk, but I think it's the head light bucket is hitting the triple clamp.
Old Aug 2, 2011 | 07:29 PM
chopper blue deuce's Avatar
chopper blue deuce
Check the 3 rubber mounts inside the shell. I had to replace mine not long ago.
Old Aug 3, 2011 | 01:50 AM
04reddeuce's Avatar
04reddeuce
When you replaced yours was the bulb moving inside the shell or more like my problem, the whole shell moving out of alignment.
Old Aug 3, 2011 | 08:24 AM
chopper blue deuce
My whole shell danced all over the place. I found the rubber insolators were shreaded.
I will try to look at it better to explain after work tonight.
Old Aug 3, 2011 | 01:58 PM
04reddeuce's Avatar
04reddeuce
ok thanks
Old Aug 5, 2011 | 01:05 AM
04reddeuce's Avatar
04reddeuce
just took the headlamp bulb off and from what I can see the 3 rubber mounts look brand new.
Ozark Joe
EVO
Jun 29, 2016 11:23 AM
Falcon195
Jul 11, 2014 12:32 PM
06BlackWG
Oct 6, 2013 07:02 PM
redheadfred
Jul 25, 2012 05:25 PM
kk6pg
Aug 13, 2009 10:49 PM
