Headlight bulb advice....
Old Aug 20, 2011 | 11:51 AM
Augustus's Avatar
Augustus
Originally Posted by oct1949
If Ur bike/light is moving that much up and down between solo and 2 up, I'd think U shocks need adjusted up to a higher load so it doesn't move so much.
I think this may be what's up with my bike, put a progressive monotube fork kit on my NT n the headlight's all over the place.
What's the fix?
I apoligize for the threadjack.
Old Aug 20, 2011 | 01:42 PM
jlasoftail's Avatar
jlasoftail
Be very careful about going to a more powerful bulb. I tried one that was on the shelf at the local dealer because the stock just doesn't cut it, and next thing you know I've got some melted connectors... I just bought a H4 but haven't got it in yet.
Old Aug 20, 2011 | 07:01 PM
jruggs73's Avatar
jruggs73
Originally Posted by grf000
Be sure it's adjusted correctly. Mine is the same bulb that's in my truck. Did have to replace the inner shell reflector that was quite messed up with age. As usually got a new take off off e-bay. What ever you do watch the amp draw. Think you only have 35 amps alternator. May even be 30 on an 01. Clunk still gone?
I set it at 35" center on the wall at 25' away with my gf on the bike with me. The HD SM said to pick what you do most of , solo or 2 up and set it accordingly. It seems like my high beam (where it's set at 35") works great but the low beam is right in front of the bike. I will check the reflector. Clunk is gone , rode 150 miles today and didn't clunk once.
Old Aug 20, 2011 | 07:02 PM
jruggs73's Avatar
jruggs73
I have progressive 413's on the back and they are as stiff as I can set them.
Old Aug 20, 2011 | 07:25 PM
jbg's Avatar
jbg
You can't go wrong with the LED bulb. It's easily twice as bright at night as the factory bulb was and covers twice the road to the side in front of you as well. I only have the one bulb in front so I keep the high-beams on full time in the daylight. Never been flashed. The bulb runs much cooler than the stock bulb as well. The light from it is a lot whiter light too. Honestly...if you get the bulb...you'll wonder why they don't put them in all the new bikes as standard safety bulbs. They're really that much better. Good luck!
Old Aug 20, 2011 | 08:24 PM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
When I got the new reflector I adjusted mine similar distance and eyeballed the center of the bright spot as they refer. Mine's fine pretty far out for 60 mph speed or so. I did knock it down a tad since on bright it was into the overhead signs, so I may have had it a tad high. You may want to carefully bump it up slightly. I guess going from two up to one makes a pretty big difference and you do not want to be blinding the cagers. Is yours the small replacement bulb and separate headlight glass? Have added adjust head bearing to my list for winter.
Old Aug 21, 2011 | 10:11 PM
jruggs73's Avatar
jruggs73
Yes it has the bulb held in with two metal clips and the glass is separate. I did have to replace the plug when I got the bike , it was burnt and once in awhile when on low beam the high beam indicator would pop on to let me know my light wasn't working. I would have no light on high or low , glad I found it during the day and close to home. Got a new plug harness and all was good.
benscratchin
Electrical/Lighting/Alarm
Sep 20, 2017 08:53 PM
hinesmc1
Mar 5, 2017 01:53 PM
Dynafrom818
Nov 27, 2012 02:20 PM
frenchbiker
Sep 2, 2012 12:19 PM
cptdenny
Jan 26, 2011 12:32 PM
