Oil Pressure Concern
Old Aug 20, 2011 | 06:47 PM
olongapo1's Avatar
olongapo1
Default Oil Pressure Concern
Bike: 2003 Night Train, Carbureted w/Mikuni 42, Stage 1, Stock Engine, Oil Cooler and Harley Oil Pressure Gauge. Low Mileage = 16,000.
I run Amsoil Syn (20W-50) and yes the oil level is correct. When starting the bike (Cold), I get 30psi oil pressure. When cruising the highway above 2,000rpm's the gauge reads between 15 and 20psi. When stuck idling in traffic the bike quickly heats up and the oil pressure drops to Zero.
I understand that the Harley oil pressure gauge is not a precision instrument but this reading of Zero definitely concerns me. Has anyone else encountered this?
Old Aug 22, 2011 | 06:22 AM
VA_Grumpy_Biker's Avatar
VA_Grumpy_Biker
have 04 Softtail. Does the same thing. When hot and idling, oil pressure will drop to near zero. I have a Ness oil gauge, so I don't think the gauge is that far off. I did put a high performance oil pump in, until it froze/locked up so went back to HD oil pump and just living with low oil pressure when hot.
Old Aug 22, 2011 | 06:37 AM
tmd442's Avatar
tmd442
I had the same issue with the Harley Gauge, threw it out and went with autometer.
Old Aug 22, 2011 | 08:59 AM
HoggyMtnBreakdown's Avatar
HoggyMtnBreakdown
Just throw out all gauges and meters you don't need by law. They just cause unnecessary worry, bro. Oil pressure gauges, oil temp gauges, tachs, etc...if Harley didn't put 'em on to begin with, you don't need 'em.
Old Aug 22, 2011 | 09:52 AM
Jim Kraft's Avatar
Jim Kraft
As long as you have pressure when riding down the road, don't worry about it. There is plenty of oil flow circulating to do the job.
Old Aug 22, 2011 | 11:13 AM
95yj's Avatar
95yj
Oil pressure gauges are worthless on Harleys. Harleys don't have oil pressure, they have oil flow. If you see oil pressure, that means your bike probably isn't warmed up yet. If you ride it when it isn't warmed up, you'll learn the joy of replacing your base cylinder gaskets.
Old Aug 22, 2011 | 12:11 PM
LocoPilot750's Avatar
LocoPilot750
My guage will jump to 45-50 lbs at a cold start, will idle at about 5-10 hot. BUT... A couple of weeks ago, the glycerine started leaking out of the gauge because the rubber plug became dislodged. Moist air replaced it and steamed up the glass. I took it off, removed the plug, flushed the guage out several times with alcolhol, let it dry, and refilled with glycerine from Walgreens. Guage problem solved. I'm still seeing the 45-50 on startup, but now at hot idle, I've been seeing it drop to 0. Just a little above idle, and it comes back up to the 5-10 range. Not too concerned, I plumbed my OP line into a "Y" beyond the sensor which is still hooked up, and so far the OP "idiot" light has not come on yet. As it turns out, all the guage does is cause anxiety.
06DEUCE
Oct 5, 2019 08:43 PM
highwayking
Sep 30, 2013 07:19 PM
corcon
Dec 16, 2008 07:20 AM
c50plus
Nov 22, 2008 08:26 AM
HDCopper
May 5, 2007 05:25 PM
