Metz 880
Old Aug 25, 2011 | 06:43 PM
Mike Willmont's Avatar
Mike Willmont
Default Metz 880
I am putting Metz 880 on my fatboy lo. What PSI would you guys recomend?
Old Aug 25, 2011 | 06:49 PM
Mr.Softy's Avatar
Mr.Softy
I just had 880's installed Sunday the dealer put 44 in the rear and 38 in the front. I am not sure if this is a good psi or not but it is what they did. Hope it helps? The bike holds the road pretty good with this pressure.
Old Aug 25, 2011 | 07:27 PM
FroggyFatBoy's Avatar
FroggyFatBoy
I run 44 in mine.. 47 2up
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Drew
Old Aug 25, 2011 | 08:32 PM
NickD's Avatar
NickD
Here's what Metzler recommends . . .
http://www.us.metzelermoto.com/web/p...s/default.page
The higher pressures I would think stems from the fact the ME 880 is a low profile tire (not much sidewall) and Metzler is worried that two up on a loaded down bike might pop the bead after hitting a bad bump in the road. But since I ride a lightweight hard tail solo (there's woman everywhere you go so why lug one around with you?) I run mine at 25 lbs. I've about 4000 miles on my rear Metzler 200 and so far no cupping or anything weird. And I've read in other Metzler threads some guys on hardtails run them as low as 16 pounds. BTW, these are the best motorcycle tire's I've ever ridden on!
Old Aug 25, 2011 | 09:06 PM
HD7585's Avatar
HD7585
I run 40 front and rear with my metzlers Seems to work well
Old Aug 26, 2011 | 08:02 AM
roadkingharry's Avatar
roadkingharry
I just switched to Metzeler's on mine. I was able to score a German made 200 rear tire from the dealer, the front was made in Brazil. Use the link above as a guide to inflate the tires and check monthly.The Metzelers handle better than the stock Dunlops IMHO.
Old Aug 26, 2011 | 12:51 PM
NickD's Avatar
NickD
I have the same combo. I'm pretty sure all the front tires are made in Brazil. But I still consider them German made as thousands of Germans fled to South America during and right after WWII. I'd bet the foreman at Metzler's Brazil factory is named Gunther, LOL!
Old Aug 26, 2011 | 02:32 PM
JIMSFBL's Avatar
JIMSFBL
Hey Nick,
I've been reading a lot about Metzler's improved handling, wear etc..., but with not a much sidewall and being worried about a blow out by hitting a pot hole, is that a concern? Is this an issue? Do you have (or anyone) have experiences on long trips with these? I'm considering them for my FLST and my FLHT and was looking for some insite.
Old Aug 26, 2011 | 03:27 PM
NickD's Avatar
NickD
I'm not an expert on tire tech but I mounted my Metzlers by hand and I can tell you that bead is very tight. I couldn't see it failing even on a horrendous pothole unless you did something horrible to your rim first. But that's a factor on any tire. On the other hand I see the smaller sidewall as an advantage. If you do get a garden variety blow out (sharp road debris) without much sidewall it's less distance to drop and less wobble while you're trying to slow down.
