scavenging oil
Old Sep 15, 2011 | 08:48 AM
cweiss's Avatar
cweiss
I generally change my own. I just was not sure about the trans and primary. Guess I am going to become familiar with it now...
Old Sep 15, 2011 | 09:29 AM
CHOPPIN' CHARLIE's Avatar
CHOPPIN' CHARLIE
Rogue Chopper has a system to completely flush the system but I mesed up the return line clip on my 96" Softail and cost me 50$ to get it fixed. Don't know what I did wrong and can't get the nerve to try it again. LocoPilot750 has a good idea as well as wlbowers. Thinking about a way to tie in to return line without messing with the plastic clip at the tank.
Old Sep 15, 2011 | 07:26 PM
05KrazyTrain's Avatar
05KrazyTrain
Originally Posted by kkiley
Sorry I misread this. Changing all the holes, they should have used almost 4 quarts. I understand now why you won't go back.
dont you mean almost 5, 2.5-3 for engine, then 1 for tranny and 1 for primary
Old Sep 15, 2011 | 08:56 PM
wlbowers's Avatar
wlbowers
Originally Posted by nikonf8
there was a listing on the forum a short while ago where a guy had a way to drain the sump without removing the return line his was done with a device that went into the filter spot and had a house coming off of it did the same thing but you never removed the return line seemed like a better way then the scavenger and it was cheaper i cant find the thread maybe someone else can
That was for the Evo engines. You can't do that with the tc engines. The oil goes from the oil pump to the filter then the engine.
Old Sep 15, 2011 | 09:04 PM
nikonf8's Avatar
nikonf8
Default pump
i was sure it was for the tc
Old Sep 15, 2011 | 10:02 PM
kkiley's Avatar
kkiley
Guess my bike is older and is different. It takes 80 oz for the engine, 26 oz for primary, 22 oz for tranny. That is 4 quarts. New ones must be different.
Old Sep 15, 2011 | 10:30 PM
05KrazyTrain
No no, im sorry i was just goin off of how you stated 2.5 quarts for motor, then just assuming a quart in the other 2 holes. you may be absolutly right. wasnt tryin to be a d!ck when i said that, basically just wanted to know if there was an error, the 4 and 5 keys are right next to each other so... my bad dude
Old Sep 15, 2011 | 10:34 PM
av8or's Avatar
av8or
They are. They made it easy on the new bikes. 3qts in the oil bag, 1 in the tranny, and 1 in the primary.
Old Sep 16, 2011 | 12:42 AM
kkiley's Avatar
kkiley
I figured it was something like that. No big deal....I just end up with partial quarts in the cabinet, lol. But out of the 15 or so people that I ride with from time to time, I don't know of 1 that scavenges their oil either....
Old Sep 16, 2011 | 12:46 AM
wlbowers's Avatar
wlbowers
If they had oil coming out of the filter bracket going into a jug on a TC engine they had NO OIL going to the engine. The oil passes through the filter before going to the engine on a TC.
It had to be an EVO engine. The oil goes directly into the engine then through the oil filter then to the tank.
Here is the oil flow path on a Softail TC.
WRE4U
Oil Archive (no new posts)
Sep 29, 2017 03:40 PM
The Cheesehead
Apr 14, 2016 03:21 PM
the4thgearkid
Apr 16, 2011 01:53 PM
dexterdave
Mar 18, 2009 02:59 PM
