help!! how do i....
Old Sep 3, 2011 | 09:55 AM
hd-kw's Avatar
hd-kw
Default help!! how do i....
Well I need some help. I need to figure out how to pull the tank off on am 06 heritage. I am tryin to install a new set of bullet turn signal lights on front light bar and apparently the connector is up under the tank. I don't want to cut and splice the wires . I removed the rear tank bolt under seat and the bolt that runs cross ways down in front of tank. It still acts like something is holding it. I'm sure a service manual would show how but I bought a service manual from a forum member over a week ago and its yet to show up. Apparently post office screwed up ? Any way any help would b appreciated. Thanks
Old Sep 3, 2011 | 09:59 AM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
All you need to do is unhook the gas line, unbolt the front of the tank, and loosen the rear tank bolt. Then lift the tank up by the front (being careful not to break the crossover under the front of the tank) The plug for passing lamps is on the left side (not exhaust side) near the front of the tank on the backbone.
Drew
Old Sep 3, 2011 | 10:10 AM
hd-kw's Avatar
hd-kw
I traced them down and with a flashlight and a screw driver to push the rubber seal out of the way I could just barely see it. Standing on my head of course. So the fuel line is all that needs removed ? I didn't remove cross over line but it felt that it was hitting something long before gettin close to it. Thanks Drew for info. U have a sweet bike btw. One of my favorites.
Old Sep 3, 2011 | 10:18 AM
inaroush's Avatar
inaroush
Drew
Thats how I did it (per Drew's advise in a prior post) on my Fatboy and it worked out perfectly. I actually as a precaution put some painters tape on the area I was working near as well to prevent accidental scratches. Just as a side note.
Drew - you're da man! Thanks
Old Sep 3, 2011 | 10:23 AM
hd-kw's Avatar
hd-kw
So u just loosen rear tank bolt , not remove ?
Old Sep 12, 2011 | 10:29 AM
hd-kw's Avatar
hd-kw
Got the tank off and lights swapped out. Fuel supply line was holding me up. Thanks again.
Old Sep 12, 2011 | 12:23 PM
AjAnd3rson's Avatar
AjAnd3rson
I think everyone needs the service manual.
Should include them with the purchase.
angeltrash1
Jan 28, 2018 04:31 AM
t059736
Mar 4, 2010 08:00 AM
klf33
May 21, 2008 12:25 PM
Sc07Sbob
Mar 3, 2008 11:26 AM
ST Deuce
General Topics/Tech Tips
Jan 13, 2007 08:08 PM
