noisy headlight
Old Sep 3, 2011 | 02:46 PM
eglinski's Avatar
eglinski
Default noisy headlight
My 2007 Deluxe, headlight vibrates and is quite audible (really getting annoying!)
It appears to be tight and attached well, I didn't notice this until after I put the "visor" trim ring on,
Has anyone else ever experienced this? any suggestions? thanks
Old Sep 3, 2011 | 10:28 PM
oct1949's Avatar
oct1949
No issue's with ours, and it has the Visor on it..
U say it appears to be tight, I'd suggest U really check it out. See if u can move it at all, it should be rock solid.
Old Sep 3, 2011 | 11:11 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
There are two tabs on the top of the headlight bucket that are supposed to have black rubber thingees on them to keep it from rattling. I lost the black rubber thingees and the same thing happened. So I got some foam insulation and wrapped it around the headlight bucket and put the trim ring back on. All good since then.
Drew
Old Sep 4, 2011 | 02:21 AM
Bluehighways's Avatar
Bluehighways
I had exactly the same rattling. Sort of sounded like the engine was pinging. But +1 on the Rubber sleeves (AKA the Dr.'s Thingees) that go on the tabs that the trim ring hooks onto. Sort of like a really small rubber band. My Harley Davidson Parts Book doesn't show them but I have to believe that a knowledgeable Dealer Parts person (is this an oxymoron?) will know what the Part Number is. Probably could put a dab of RTV sealant on the tab and let it dry for 24 hours before re-installing the Trim Ring . . . .
paulmj
2018+ Softail Models
Jun 18, 2019 10:35 AM
Valdez2068
Apr 7, 2016 11:39 AM
rsalway
Feb 2, 2015 07:54 PM
IAMSWUTIAMS
Softail Parts
Jun 1, 2009 08:48 PM
rockerheadsteve
Nov 20, 2008 11:50 PM
