Load Equalizers - What do you use?
Old Sep 10, 2011 | 06:40 AM
cmosentine's Avatar
cmosentine
Default Load Equalizers - What do you use?
I am curious what brand of load equalizer do you use with your LED turn signals? Badlands Illuminator looks good but is not water tight and the wire bundle in not protected. Biketronics has a good looking unit but it does not have run/brake/turn.
Also, where did you place the module? Not much room on my bike under the seat. Perhaps behind the the splash guard?
Old Sep 10, 2011 | 08:26 AM
jreichart's Avatar
jreichart
Got my LED strips and load equalizer from Custom Dynamics. Had them about 2 years now, no issues at all so far. Put the EQ under the seat.
Old Sep 10, 2011 | 11:36 AM
PanHeadRich's Avatar
PanHeadRich
I went with Kurakyn's Rear Run-Turn Brake Controller and I'm very happy with the product. They come with full simple instructions. The module requires less space than you may think, and it does fit right under the seat. The Run-Turn Brake Controller is cool because your rear signals become brake lights as well. It also has an option for 3-pulse brake light flashing. When you hit the brakes, the flash 3 times before the brake light stays on. But if you just want a simple load equalizer, they have them as well.
Check out their page: http://www.kuryakyn.com/Harley/Light...oad-Equalizers
Here's a link to a half-a$$ youtube video showing you how it works: http://youtu.be/wNC4Q2uvaMs
Old Sep 13, 2011 | 08:55 AM
Ash16's Avatar
Ash16
Me too.
Old Sep 13, 2011 | 09:10 AM
Rakthi's Avatar
Rakthi
Run/Brake/Turn from Custom Dynamics, I put the load equalizer is on top of the battery.
Old Sep 13, 2011 | 09:17 AM
jetmech74's Avatar
jetmech74
Badlands here
Old Sep 13, 2011 | 11:47 AM
mimo's Avatar
mimo
Custom Dynamics.
Old Sep 13, 2011 | 08:00 PM
cmosentine's Avatar
cmosentine
Thanks for the replies. I decided to go with Badlands r/t/b module, LED tail and turn signals.
Old Sep 13, 2011 | 11:41 PM
RocketRocker's Avatar
RocketRocker
Good choice, you wont be disappointed with Badlands
Old Sep 14, 2011 | 01:30 PM
pnw_hd_rider's Avatar
pnw_hd_rider
Tail/running lights and brake lights don't need 'equalizing'. The only issue with LEDs is with the turn signal flasher. Some 8 ohm resistors from radio shack for a buck apiece (one for each turn signal) work perfectly for LED turn signals.
