Poor MPG
Old Sep 12, 2011 | 06:44 AM
sammer4u's Avatar
sammer4u
Default Poor MPG
I have a 02 Heritage EFI with 26,000 miles on it. I put on Python Slip ons, the stage one kit, and the Fuel Moto EFI tuner. Just a week ago I had to install new cams, and put in SE 220. Before all this work I was getting a minimum of 40 MPG and over 200 miles on the trip meter before I had to look for gas. Now I am getting 28 MPG or just over 100 miles before needing fuel. Any thoughts on what is going on?
Yesterday I filled up with 3.506 gallons of gas and I had exactly 100 miles on the trip meter.
Frustrated is the politically correct term I can come up with at the moment.
Old Sep 12, 2011 | 07:02 AM
Miked053's Avatar
Miked053
I would get on the horn with Fuel Moto and get their take on it. You also have to remember that with cams your going to use more fuel especially because of your right hand
Old Aug 21, 2022 | 03:25 PM
Docmel's Avatar
Docmel
Posts like this crack me up. The bottom line that HDs are underpowered are that they are tuned VERY lean to meet emssions. When you add perf parts, and especially the tuner, you are making the engine run richer (MORE FUEL) which makes more HP. The way you get HP is more air/gas in = more air out, which again = more HP
An engine is like an air pump. More in with more out = HP
Dont trust your est MPG though: The only way you can really get true MPG is to drain the tank completley empty, put exactly 1 gallon of gas and ride until the bike dies
Old Aug 21, 2022 | 03:49 PM
CoolBreeze3646's Avatar
CoolBreeze3646
Congrats on the resurrection of an 11 year old thread, I'm sure he has it worked out by now............just saying. I'm sure your knowledge of the MPG subject will assist others seeking this type of information.
Best regards...........
Old Aug 21, 2022 | 08:46 PM
Cap77's Avatar
Cap77
no offense, but that sounds like a BIG PITA to me
I'd suggest an easier (though will take longer and lots more miles) to gauge accurate mileage, is to fill up at the same pump, with bike in same position on the stand and same fill level thru several tanks full.
same pump and same bike position on the stand takes different uneven/sloped lots out of the equation.
as long as you're not running the chit of it for one tank full and driving like miss Daisy on second tank full, by the third and forth tank full you'll know accurately what you practical mileage is to the ounce
..L.T.A.
Old Aug 22, 2022 | 01:04 AM
Docmel's Avatar
Docmel
1. Post popped up on top of the list when I opened the forum. I dont look at dates. I only answer the posts to help the OP or others who may have the same or recent prob
2. The OP never stated he solved the issue> I guess you dont want folks to chime in
3. Instead of being sarcastic to others because they show interest and are willing to respond, too bad you dont have helpful input
4. So whats YOUR answer?
Just saying..............
Old Aug 22, 2022 | 07:54 AM
eighteight's Avatar
eighteight
My answer is with cams, increased compression and a larger bore I still get 42 mpg
RottnRam
Sep 14, 2015 08:45 AM
99superglide
Apr 1, 2011 01:08 PM
07 dyna man
Nov 3, 2009 07:21 PM
pork
Aug 10, 2009 10:50 AM
smittyp83
Jun 16, 2007 10:33 PM
