Another cam confusion plz help....
Old Sep 13, 2011 | 11:57 PM
sandhu22g@yahoo.com's Avatar
sandhu22g@yahoo.com
Default Another cam confusion plz help....
Well i am doing 95 big bore kit on my fatboy not doing any head work,(i kno i should do some head work but no money left for that). and i have SE 204's and CVO 253 sitting at home. i really dont have any idea which one is better or should i look for any other. i really wana do it once. most of my riding is in town and i do ride hard. plz give any advice..
thnx
Old Sep 14, 2011 | 09:30 AM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
I'd do the 204's.
Drew
Old Sep 14, 2011 | 07:39 PM
TheTroupe's Avatar
TheTroupe
Originally Posted by DR. V-TWIN
I'd do the 204's.
Drew
+1 on the 204 for your riding style.
Old Sep 14, 2011 | 09:06 PM
KumaRide's Avatar
KumaRide
204's. Check into decking the heads to increase compression some. Cheap, ~$75 for both heads. Depending on mileage, reuse the stock push rods to save some money. Lifters may need replacing. Inner cam bearings for sure.
http://www.bigboyzheadporting.com/TwinCamComp.htm
Old Sep 15, 2011 | 12:51 AM
oct1949's Avatar
oct1949
the 253 will be soft in the lower-mid rpm's with the 53 IC. If U ride above 3500 rpms all the time U might like them be better.
I will add the Son had 2 softtails with the 204's and loved them and of the two, they would be my pick.
Old Sep 15, 2011 | 06:00 AM
roadkingharry's Avatar
roadkingharry
When I did my 95 build, I had the heads decked and cc'd only, to match the cam,cost $100. I was doing a budget build. In hindsight, I should have waited just a lil bit longer and saved another $300 to get the bigboyz street port. Patience can be a virtue when doing these builds if budget is part of the equation.Also,like Kuma said, r&r inner cam bearings to Timken B148's, install Baisley spring in cam plate, check tensioners for wear. I used a Cometic .030 head gasket.
machinehed
Jan 6, 2020 06:42 AM
83harley@
Screamin Eagle CVO Models
13
Dec 20, 2018 05:22 AM
jammerx
2014-2024 Touring Models
31
Dec 11, 2018 06:33 PM
msamarah86
Oct 17, 2011 11:34 AM
2005flstfi
Exhaust System Topics
Oct 20, 2006 12:22 PM
