2010 fatboy LO
Old Sep 17, 2011 | 07:35 AM
Kojax's Avatar
Kojax
Cool 2010 fatboy LO
i have the 2010 fatboy lo with the stock handle bars. i really do not want to changne the stocks bars i need them alittle closer does harley make anything like this. thanks alot RIDE SAFE
Old Sep 17, 2011 | 07:42 AM
Josewales's Avatar
Josewales
Same. I find myself a little to much pulled forward with the stocks. I love the height but could use a few inches back for kick back comfort. I thought about repositioning, but the way it's bent the controls would feel a little awkward and twisted.
Old Sep 17, 2011 | 08:00 AM
serjayson's Avatar
serjayson
Since you don't want to change the bars you could change the risers for ones with more pull back.
Old Sep 17, 2011 | 08:25 AM
HoggyMtnBreakdown's Avatar
HoggyMtnBreakdown
+1
Here is pullback riser for 1.25" bars from Harley. Available in 6" or 4". A little steep at $170 and I don't see it in black, but there are probably aftermarket versions, too.
Old Sep 17, 2011 | 08:28 AM
Santo's Avatar
Santo
Maybe some risers off a Deluxe will work for ya. They have plenty of pull back.
Old Sep 17, 2011 | 09:22 AM
harleyfiremedic's Avatar
harleyfiremedic
Had the same issue, Tried the 4" pull back risers. They really didn't help much. I also tried the reach seat, that also didn't really help much. After lots of thinking and looking I ended up putting the stock Fatboy bars on. Had to change the wires etc, but it made it much more comfortable. I kept the pull backs, but have gone with a Mustang seat.
Old Sep 17, 2011 | 09:27 AM
SNAKEMAN's Avatar
SNAKEMAN
I read somewhere that the 2012 lo has more pullback on the bars, may be an option for you.
Old Sep 17, 2011 | 09:31 AM
paud's Avatar
paud
I put on 4" pull back risers. It helped. I also realized the Lo is set up to make one sit more rigid and lean forward a bit. More of an "aggressive" posture.
Old Sep 17, 2011 | 02:50 PM
jbg's Avatar
jbg
Wild1Chubby's bars gave me 14.5" of pullback. The 4" risers will only give you 1" of actual pullback.
Old Sep 17, 2011 | 04:58 PM
Kojax's Avatar
Kojax
Cool
hello again i am thinking of getting the harley 4 inch riser, how hard is it to put on or should the dealer do it. thanks
