TOURQUE WRENCH HELP
Old Nov 22, 2006 | 09:19 PM
softail2005's Avatar
softail2005
Default RE: TOURQUE WRENCH HELP
There are many areas that require the use of IN LBS on a Harley so I suggest you invest the $70 bucks at sears and get one with IN LBS also. Thats what I did and its the most accurate way to get things done correctly.
Old Nov 22, 2006 | 09:49 PM
keneds's Avatar
keneds
I just bought it last night and the package say "DUAL SCALES provides inch and metric setting capability" so I figured it had and inch scale and it has ft. pounds on one side and newton meters on the other side.
I must have been mislead.
Old Nov 22, 2006 | 10:58 PM
Jim Dawson's Avatar
Jim Dawson
ORIGINAL: keneds
I don't think you were mislead, it has English and metric scales, "DUAL SCALES". I suspect you will need ft. lbs and inch lbs when you work on your bike, so you might as well go buy the in.lbs version now.
Old Nov 22, 2006 | 11:51 PM
cwsharp's Avatar
cwsharp
If you're going to get in to the business of maintenance, you should have both a foot/newton torque wrench and a inch/whatevermetric torque wrench. Go back and buy the inch pound wrench and keep your big one too.
C#
Old Nov 22, 2006 | 11:57 PM
cowboy Harry's Avatar
cowboy Harry
I tried using a tork wrench a while back. Heck with that. I d rather let my fingers tell me its tight enuff.[8D]
Old Nov 23, 2006 | 12:14 AM
kenny's Avatar
kenny
Maybe this will help you out https://www.hdforums.com/m_88059/tm.htm
Old Nov 23, 2006 | 12:49 AM
billvaughn's Avatar
billvaughn
Buy an inch lb wrench and forget the guess work.....
[IMG]local://upfiles/2670/E372259E0E0A40CCAE768CFC8396E9EE.jpg[/IMG]
Old Nov 23, 2006 | 06:28 AM
cajunman831's Avatar
cajunman831
make sure you know how to use it.or you,ll over torque something to much.i use the one with the indicator.easier to use.only craftsman tools
Old Nov 23, 2006 | 01:38 PM
mopardave's Avatar
mopardave
Yeah, these will work just fine:
TOOL # 8000733592- 1/2 inch drive- 25-250 FOOT lbs- $109.99- MODEL #944597 Digital unit, real nice to work with.
Tool # 4030681248- 3/8 inch drive-20-150 FOOT lbs. - $74.99- MODEL #944595
Both made by craftsman, good units, both are the clicker types
Tool- 3/8 inch drive- 25-250 INCH pounds- $74.99 -Model #944593
Don't forget to get the case to protect them.
[sm=icon_ladiesman.gif]
Old Nov 23, 2006 | 09:09 PM
Reino's Avatar
Reino
ORIGINAL: cowboy Harry
Some people just have the knack or feel, I must admit most of the time I don't use it either.
