Docking Hardware
Old Nov 25, 2006 | 12:44 AM
tmitchellof PG's Avatar
tmitchellof PG
Default RE: Docking Hardware
I will cut the wires if I have to. I started to work on the bike, figuring I would remove the stock rear signals and put the saddle bag hardware and bags on. I found out the wires for the signals rout through the hole where they were originally mounted, about an inch forward. This meant if I mounted the bags now I would have to remove the bags and the attaching hardware to get the fender struts far enough away from the fender to rout the wires for the new signals. I put everything back together the way it was until my new signals arrive next week. I did manage to get the 3 bolts on each fender strut loose. They were really tight with the loctite they used.
Do I understand correctly that all I have to do is remove the nut inside the fender behind the tail light to access the wire connections for the signals. I was thinking I had to remove the tail light.
Tom
Old Nov 25, 2006 | 12:27 PM
mopardave's Avatar
mopardave
[sm=icon_rtfm.gif][sm=icon_rtfm.gif]<--------------
Protocol
Apr 8, 2017 10:39 AM
Hossfly
Jun 25, 2010 10:06 PM
Smitty79
Apr 2, 2010 11:32 AM
2004FATBOY
Jun 16, 2008 09:24 PM
SSGBobber
Apr 14, 2008 12:46 PM
