starter removal
Old Sep 28, 2011 | 09:34 PM
bud42's Avatar
bud42
Stage IV
Default starter removal
I need to take my starter off, I have a 94 Heritage softail, do I really need to remove the primary cover and jackshaft to do this?
Old Sep 28, 2011 | 10:11 PM
Tee&Vee's Avatar
Tee&Vee
Default Yes
Yes to the primary cover! There is an AWESOME video on YouTube for this on an Evo motor.
Old Sep 28, 2011 | 10:13 PM
dieselguy65's Avatar
dieselguy65
when you put it back together, leave the stupid retaining clip off the shaft. makes the job a side of road thing if need be next time.
Old Oct 1, 2011 | 06:20 PM
indiablue's Avatar
indiablue
I'm doing the same thing right now on my 91 heritage. I was told yes but I'm having blast trying to get the one bolt behind the floorboard off. Floorboard does not want to be moved. Soaking it with some penetrating oil. How did you do?
Old Oct 2, 2011 | 08:39 PM
bud42's Avatar
bud42
Stage IV
Thanks for the info, I have not taken it off yet....I took the cables off and the end on the starter had some corrosion on it so i cleaned them and hope that fixes my problem which was it would not start all the time, it would just click like the solenoid was not engaging or a low battery but everything would test fine.
Old Oct 3, 2011 | 04:03 AM
piperbob's Avatar
piperbob
Pull the solenoid cover and clean the plunger contacts, that might be causing your problem.
Bob
97 Heritage
Old Oct 4, 2011 | 06:25 PM
bud42's Avatar
bud42
Stage IV
Thanks Bob I just cleaned them because it did it again today so we will see if this works.
Kidharley
Sep 1, 2014 08:16 PM
SecondChance!!
Jul 5, 2011 10:03 PM
BigTone24
EVO
Jul 2, 2011 12:00 AM
98 Heritage N.Indiana
EVO
Feb 21, 2011 10:54 PM
GRNBRT79
Jun 3, 2010 09:48 AM
