Which brake fluid
Old Oct 6, 2011 | 07:52 PM
hogster1961's Avatar
hogster1961
Default Which brake fluid
I've just changed the bars on my bike and was set to bleed the front brake, then I noticed that the rear master cylinder cap says use Dot 5 the front M/C cap says use Dot 4?
I'm thinking the front master cylinder has been changed(I suspect the bike has been dropped by the P.O) so should it be Dot 5 all round? the manual I have doesn't even mention Dot 5.
The bike is a 2006 Fat Boy.
I know that 4 and 5 don't mix so if I go with Dot 5(which I would rather as I have a custom paint job) will I need to completely strip out the front calliper or is it enough just to flush it through with the new (Dot 5) fluid?
Thanks for any help/advice.
Old Oct 6, 2011 | 08:32 PM
sagebrush1976's Avatar
sagebrush1976
I just changed the brake like on the front of my 06 FXST and it called for DOT4 also.
Old Oct 6, 2011 | 08:37 PM
scasey's Avatar
scasey
My manual for an 06 says Dot4. I own a 2006 heritage. Can't help any further with the flushing out thing.
Old Oct 7, 2011 | 10:36 AM
oct1949's Avatar
oct1949
don't know bout Ur 06, my 07 says Dot 4 both front and rear.
Maybe one of them had the caps changed out
Old Oct 8, 2011 | 12:24 AM
Mr. Lucky's Avatar
Mr. Lucky
Pop the mc lid and see what's in there. DOT 4 comes in a variety of colors (I've seen blue, clear, and a variety of amber shades), but DOT 5 is always purple.
Old Oct 8, 2011 | 01:24 PM
Tom84FXST's Avatar
Tom84FXST
Dot 5 is always purple when you open a new sealed container...but once it is exposed to air, the purple goes away and it is amber. I always run dot 5 no matter what, because I am not getting dot 4 near nice paint. You can run dot 5 in any system, but I have never tried to flush out a system...I don't think you could get all the dot 4 out without disassembling the system...rebuild kits are cheap insurance.
Old Oct 8, 2011 | 06:33 PM
poppavein's Avatar
poppavein
DOT 5 fluid is highly compressible due to aeration and foaming under normal braking conditions, providing a spongy brake feel.
Harley switched to DOT4 when they started delivering ABS systems. DOT5 is not recommended for ABS systems due to this problem with aeration. Possibly the ABS unit itself can generate those bubbles when it is activated. (Which doesn't really make sense in a sealed system.)
Old Oct 8, 2011 | 07:09 PM
Tom84FXST's Avatar
Tom84FXST
Dot 5 is not recommended for ABS because it lacks lubrication qualitys which can screw up the valves in ABS. Both my Harley and Corvette have rock hard brake pedals with dot 5.
freebyrd
Jul 4, 2017 06:14 AM
fhartell14
Apr 18, 2017 09:04 PM
gartec81
Mar 1, 2014 02:39 AM
mayo
Wheels/Tires
11
Dec 26, 2011 04:42 PM
crazybastid83
Mar 13, 2009 09:40 PM
