tach dont work?
Old Oct 9, 2011 | 02:40 PM
prost34's Avatar
prost34
Default tach dont work?
Just hooked up my harley tach on my 2007 softail,has power orange ,ground black,hooked the pink to the speedo post but does not work,not sure if its in the right spot,pink plug on speedo?
Old Oct 9, 2011 | 07:14 PM
Sgt_Jim's Avatar
Sgt_Jim
what do the directions say to do with it?
Old Oct 9, 2011 | 07:15 PM
prost34's Avatar
prost34
i hooked it up the way they want,but it was for a fx and a softail,the wiring for a fx
Old Oct 9, 2011 | 07:38 PM
prost34's Avatar
prost34
anyone know where i can find the tach signal wire?
Old Oct 9, 2011 | 08:41 PM
TheTroupe's Avatar
TheTroupe
What does your service manual say?
Old Oct 9, 2011 | 08:58 PM
Tee&Vee's Avatar
Tee&Vee
What terminal is not in use? From memory it should be 5 or 6... One is the turn signal module. You could add power for the light and black for the ground then go old school and put the wire to one of the spark plugs. This is a reliable method. U can go to the ignition coil too or instead.
I use Clymers manual and it has a few good descriptions of the wiring terminals.
Tom
Old Oct 10, 2011 | 07:10 PM
MCSarge's Avatar
MCSarge
You need to pick up the tach signal at the connection to the computer. Do a search it has been mentioned many times over the past couple of years. If you use the pink wire in the harness by the front of the bike the tach won't work. Here's the link I found it for you. As stated some later models the wire at the speedo doesn't work
https://www.hdforums.com/m_65101/tm.htm
Old Oct 11, 2011 | 07:11 AM
prost34's Avatar
prost34
thanks!!
kingke
Apr 2, 2025 12:24 PM
BrianK
Feb 15, 2022 07:53 PM
mike79
Jun 1, 2012 11:03 PM
aharper
Dec 12, 2011 12:40 PM
2goldens
Mar 11, 2008 06:02 AM
