Speedo/Tach Combo
Old Aug 14, 2005 | 11:45 PM
2goldens's Avatar
2goldens
Default Speedo/Tach Combo
Just had a new speedo/tach combo delivered. Part#74461-03A clearly states '00 - '03 Softails except Deuce. Went to install it on my '02 Fat Boy and discovered that the wiring diagram that came with the unit is not quite right. The hole in the OEM speedo plug that very clearly should have been blank for the pink tach wire from the OEM harness to plug into aleady had a wire there. Fortunately, a friend who is a mechanic at my local mom and pop bike shop happened to be there. He'd seen lots of these units. Popped the plug apart and inserted said pink wire from factory harness into an altogether different hole and guess what? Tach and speedo working just fine. Thanks for the mass confusion and F'd up directions, H-D. Like $419 wasn't enough for the speedo/tach unit. You also had to give bum instructions that gave me a chance to ruin it during installation.
Old Feb 28, 2007 | 02:55 AM
cg2's Avatar
cg2
1st Gear
Default RE: Speedo/Tach Combo
Hey,
I am having a similar problem trying to get the tach to work on the speedo/tach combo unit. Can you give me a better description of what wire and where it is supposed to go? Thanks!
Old Mar 11, 2008 | 06:02 AM
uh60surgeon's Avatar
uh60surgeon
4th Gear
I have the same problem, could you be more specific on where the pink wire gets connected? Thanks
BrianK
Feb 15, 2022 07:53 PM
Stelter
Mar 23, 2021 10:41 AM
texas-buzzard
Aug 4, 2009 03:02 PM
oldairboater
Jan 13, 2008 10:33 PM
harris48cars
Oct 16, 2005 10:33 AM
