Compensator Nut
Old Oct 26, 2011 | 12:43 PM
wolfprint's Avatar
wolfprint
Default Compensator Nut
04 Heritage 40,000. bought it with 23,000 had some front end engine noise, figured it needed new chain tensioners so pulled the bottom end and replaced everything including a different cam while I was in there. Put it all back together but same noise, finally figured out it was compensator nut. Tightened to 165 lbs. Noise gone, bike runs great. Running down the highway the other day, pulled off and noise back. Sure enough compensator nut finger loose again. Locktighted before, only 6-thousand miles later its loose again. Not a good sound to listen to for 600 miles to get home. Anybody else with this problem. Having to keep tightening the compensator nut.
Old Oct 26, 2011 | 02:05 PM
pnw_hd_rider's Avatar
pnw_hd_rider
Did you use red locktite or blue?
Old Oct 26, 2011 | 02:49 PM
Jester750's Avatar
Jester750
Here's a couple of threads on the subject.
I just did a quick search on the forum for (compensator nut) and came up with a ton of stuff.
https://www.hdforums.com/forum/touri...it-w-pics.html
https://www.hdforums.com/forum/touri...mpensator.html
Old Oct 26, 2011 | 07:07 PM
FroggyFatBoy's Avatar
FroggyFatBoy
great info in that first link jester.. thanks..
i think i'll be adding a SE compensator to my winter mods..
Old Oct 26, 2011 | 09:43 PM
oct1949's Avatar
oct1949
Must not be just the 96''ers,, as some thought.
loctite that baby.
oct1949's Avatar
oct1949
loctite that baby.
Old Oct 28, 2011 | 10:18 AM
wolfprint's Avatar
wolfprint
Used the red but after looking at it may not have cleaned that spline thouroughly enough before putting it back together.
Old Oct 28, 2011 | 10:19 AM
wolfprint's Avatar
wolfprint
Used the red, but after looking at it may not have cleaned that spline thouroughly enough before putting it back together.
Dagnabbit
Jun 1, 2017 05:15 AM
2kids3pets
Apr 3, 2015 02:25 PM
jacknthebox
Aug 25, 2013 01:08 PM
dkitch
Jul 16, 2011 06:03 PM
SkidderCycles
Sep 26, 2009 12:18 AM
